Grapple ATI Grapple
/ ATI Grapple #1
Vermonster
Fairfax, Vermont
NH TC29S
Does anyone have any experience with ATI's grapple attachment? Info on this thing is at <A target="_blank" HREF=http://www.pfvirtualfarmshow.com/new_products/1101a.asp>http://www.pfvirtualfarmshow.com/new_products/1101a.asp</A>
/ ATI Grapple #2
Michael
I looked into one for my 2910. Decided to make my own.
<A target="_blank" HREF=http://www.carverequipment.com/>Carver Equipment</A> carries the ATI grapple. The main concern for smaller compact tractors is the weight of the grapple may limit the amount that can be lifted with your FEL.
/ ATI Grapple #3
really nice work on your grapple. what size ram did you use and how are you controlling it?
/ ATI Grapple #4
Rob
I'm using a Lion 2" bore X 8" stoke cylinder. Pin center length is 18 1/4". I have a separate valve mounted under my loader valve. I have a set of hydraulic hoses that go to the front of Loader frame. There are a set of quick disconnects at this point. It allows me to remove Grapple by pulling 2 pins for cylinder, 2 pins for grapple arms and the quick disconnects. Frame stays on Loader bucket. The whole assembly weighs 170 lbs.
/ ATI Grapple #5
great I appreciate it, was thinking of building one for the kubota for capturing sewer and water pipes( those 20' lengths of 6" schedule 80 waterpipe are heavy).
/ ATI Grapple #6
Rob
Something similar to what I made should work great. I have a 30' Telephone Pole that I used to try mine out with. Ounce I learned the technique needed to pickup a 12" diameter pole. It sure beat using chains.
/ ATI Grapple #7
Ron - That's a very nice job! You'll find plenty of uses for it, I'm sure!
/ ATI Grapple #8
i've just bought 1 and still am working on plumbing it correctly .it will make moving logs and brush much easier
/ ATI Grapple #9
Did you buy it direct or through a dealer? How expensive are they? How good are the instructions? Pictures???? We love pictures... /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
/ ATI Grapple #10
junkman i got it from carver my local dealer didn't know they made small grapples .As for pictures opps!! deleted instead of downloaded from camera I will post new ones after next week.Price was about $750 with shipping and new control valve
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
UNUSED WOLVERINE QUICK COUPLER 10 (A64281)
UNUSED WOLVERINE...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
Informational Lot - Financing (A63689)
Informational Lot...
