atachments
   / atachments #1
Aubrey foster
1987 John Deere 750
Just bought a John Deere 750. I was told I could run 5' atachments but my buddy has a 5' box & finish mower and when I picked up on his equipment it seamed like it was a little much for the tractor. So anyway I want to buy right equipment for my size tractor. What ya think
   / atachments #2
5' Finishing mower, yes...should be no problem. 5' box blade might be too much (due to the 750's light weight).
   / atachments #3
I ran a 5ft BB on the MFWD (4x4) 750 I used to have and it pulled it pretty well. Of course, the MFWD really helped a lot, along with the ag tires and wheel weights it had. As with most tractors, you can eventually find the "stall point" if you load up the box with enough wet dirt/gravel/etc no matter what size the BB is. The trick is to try to get no more material in the box than you know will probably bog it down to keep from spinning the tires.
If the OP's 750 is 2 wheel drive, has turf tires, or no wheel weights, his stall point will definitely be a bit lower. He could still run a 5 ft BB to be able to cover the tire tracks nicely, but just have to watch it to not "overload" the box, or dig with all 5 rippers in the ground. Operator experience will go a long ways to using any tractor and boxblade to its fullest capabilities.
I did run a 4ft bush hog on the 750 though, that was really all it wanted to handle too. The 750's I had did not have a loader on them so the front end was fairly light with the 4ft bush hog on the back. I just think a 5ft bush hog would be too much for that 21hp tractor. I know the OP didn't mention getting a bushhog, but I thought I would point that out just in case he did get one at some point.
The 750's are actually great little tractors though! I've actually owned two of them, the first one was '81 two wheel drive 750 that I had for about 5 years, then had a chance to trade up to a '84 4x4 750. Liked them both, but eventually decided I wanted a loader so I sold the '84 and got the 790 I have now. I hope you enjoy your 750.
   / atachments
Thanks for the info. Looks like I have alot to learn about tractors
   / atachments #5
A 750 Deere can handle the lighter 5' attachments. As long as the box blade is between 350-450 Lbs. The John Deere BB2060 would be about the biggest you should go. There are some 5' box blades that weight 750+, and you should not use them.
Try and find specs on your tractor: HP, PTO HP, Hitch lift capacity. Then match the attachments to those specs.
Towable Diesel Generator (A59228)
Towable Diesel...
16001 (A55853)
16001 (A55853)
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
2014 International Derrick Digger Truck (A55973)
2014 International...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
