ASV rc-30 --- ran over bump, engine sputters and dies
   / ASV rc-30 --- ran over bump, engine sputters and dies #1
queen of spades
Earlier today while clearing brush, I ran over a bump and the engine started cutting out.. A moment later it died. It would start up for a second or two the first couple of tries, then it wouldn't start at all.
The machine ran fine all day on the same tank of gas (more than half a tank still left). I've bled/primed the lines but it didn't help. Checked for loose wires - everything seems to be OK. It is a Caterpillar 3-cylinder (ASV track loader).
Any suggestions?
   / ASV rc-30 --- ran over bump, engine sputters and dies #2
Any suggestions?
Same thing happens with my DTA466, except it happens when I go around a sharp curve once in a while. I'm getting air from somewhere.
I think you're sucking up air somewhere. I just keep pumping the primer handle and cranking until it restarts.
I'm going to replace my fuel lines first, then go from there. Have you checked your fuel lines for a loose clamp or possibly a fuel line that is not pushed all the way on tank, pump, etc?
   / ASV rc-30 --- ran over bump, engine sputters and dies #3
Might try to take off the fuel pick up line from the tank & blow back through it!! My rc-100 will do that when trash gets down to the pick up just before coming up into the rubber fuel line!
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A53843)
2019 TY-CROP...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2006 TerraGator 8104 (A53473)
2006 TerraGator...
2013 F-550 Bucket Truck (A53473)
2013 F-550 Bucket...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
