ASV rc-30 --- ran over bump, engine sputters and dies
   / ASV rc-30 --- ran over bump, engine sputters and dies #1
queen of spades
Earlier today while clearing brush, I ran over a bump and the engine started cutting out.. A moment later it died. It would start up for a second or two the first couple of tries, then it wouldn't start at all.
The machine ran fine all day on the same tank of gas (more than half a tank still left). I've bled/primed the lines but it didn't help. Checked for loose wires - everything seems to be OK. It is a Caterpillar 3-cylinder (ASV track loader).
Any suggestions?
   / ASV rc-30 --- ran over bump, engine sputters and dies #2
Any suggestions?
Same thing happens with my DTA466, except it happens when I go around a sharp curve once in a while. I'm getting air from somewhere.
I think you're sucking up air somewhere. I just keep pumping the primer handle and cranking until it restarts.
I'm going to replace my fuel lines first, then go from there. Have you checked your fuel lines for a loose clamp or possibly a fuel line that is not pushed all the way on tank, pump, etc?
   / ASV rc-30 --- ran over bump, engine sputters and dies #3
Might try to take off the fuel pick up line from the tank & blow back through it!! My rc-100 will do that when trash gets down to the pick up just before coming up into the rubber fuel line!
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
