ASV rc-30 --- ran over bump, engine sputters and dies
   / ASV rc-30 --- ran over bump, engine sputters and dies #1
queen of spades
Earlier today while clearing brush, I ran over a bump and the engine started cutting out.. A moment later it died. It would start up for a second or two the first couple of tries, then it wouldn't start at all.
The machine ran fine all day on the same tank of gas (more than half a tank still left). I've bled/primed the lines but it didn't help. Checked for loose wires - everything seems to be OK. It is a Caterpillar 3-cylinder (ASV track loader).
Any suggestions?
   / ASV rc-30 --- ran over bump, engine sputters and dies #2
Any suggestions?
Same thing happens with my DTA466, except it happens when I go around a sharp curve once in a while. I'm getting air from somewhere.
I think you're sucking up air somewhere. I just keep pumping the primer handle and cranking until it restarts.
I'm going to replace my fuel lines first, then go from there. Have you checked your fuel lines for a loose clamp or possibly a fuel line that is not pushed all the way on tank, pump, etc?
   / ASV rc-30 --- ran over bump, engine sputters and dies #3
Might try to take off the fuel pick up line from the tank & blow back through it!! My rc-100 will do that when trash gets down to the pick up just before coming up into the rubber fuel line!
Valvoline 85/140 Gear Oil (A53117)
Valvoline 85/140...
2018 Ford F-150 Pickup Truck (A53117)
2018 Ford F-150...
2017 Can-Am Side by Side (A51694)
2017 Can-Am Side...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2006 Mercedes-Benz E350 Sedan (A51694)
2006 Mercedes-Benz...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
