ASV PT100 w/pressurized cab
   / ASV PT100 w/pressurized cab #1
AX MAN
Tuscaloosa,Al
Kubota 7010 4wd
Has anyone tried one of these yet?
   / ASV PT100 w/pressurized cab #3
I've been trying to get a rental on a conventional cab PT-100 w/ AC but the dealer says no luck on a pressurized unit...too specialized to put into a rental fleet...
I'm hoping someone in the Northeast is putting together a demo...Quickdraw do you know of anything?
-TMTS
   / ASV PT100 w/pressurized cab #4
I have not heard of any BUT I have not been looking either.
I did check out a Mustang 2109 today...big rig. Might rent one as back up for some rotary mowing.
   / ASV PT100 w/pressurized cab #5
Ive just been quoted $88,000 for a 2109 with over tyre grouser tracks . The only thing that concerns me is the low ground clearance and the fact that they have dropped from 115hp to 90 something which is why i was interested in the first place .
I have not heard of any BUT I have not been looking either.* I did check out a Mustang 2109 today...big rig.* Might rent one as back up for some rotary mowing.
I also have a 2006ASV with an air conditioner that has never worked properly how does yours work?
I am also now after 1100 hours experiencing hyd. oil temp light glowing after 45min. of running.
   / ASV PT100 w/pressurized cab #7
Which ASV do you have? The Red Dot air conditioning systems are one of the best. Our Northeast 90 is no problem for my unit on the SR80.
jmf
   / ASV PT100 w/pressurized cab #8
My AC stopped working but it ended up being the fins were completely block with dust and pollen. Cleaned it and it works fine now. 1080 hours today 2006 RC100.
Quoted 55K for 2109 with out tracks.
Might want to power wash the hyd oil cooler really good...
jmf
I have the factory AC. I do not have the Red Dot. Yellow Dog suggested I try one but I do not want to spend more than I have to. I keep thinking Terex will improve the ASV.
   / ASV PT100 w/pressurized cab #10
Are you sure the factory AC is not the Red Dot?
jmf
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
1986 Nissan King Cab Pickup (A52384)
1986 Nissan King...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2007 Yamaha Rhino 660 (A53473)
2007 Yamaha Rhino...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
