Assuming battery but thought I'd ask the experts
   / Assuming battery but thought I'd ask the experts #1
wxtrendsguy
Breinigsville
Kioti
2014 DK45 cab tractor. Used it on Sunday with no issues. Tried to start it Monday, turned key to heat plugs and indicator came on then when ready turned to on and "click" everything is dead and only the oil indicator light is barely on. Probably been 4 years since last battery replacement. Tried to jump start it from truck and no luck, put a trickle charger on it all night and again lights on dash lit up but turned key and dead.
If battery what size and cranking amps am I looking for. The owners manual is somewhere in a building but I cannot find it if my life depended on it...lol
   / Assuming battery but thought I'd ask the experts #2
Load test the battery to be sure, probably need to charge it first. Yes it’s probably the battery.
   / Assuming battery but thought I'd ask the experts #3
It does sound like a failed battery, but as Dodge Man suggests a load test is in order.
For replacement, if the BCI size and CCA information is not printed on the battery you can measure what you have and reference a BCI table for something that will fit. Pay attention to the terminal orientation also.
  • Good Post
Reactions: JJT
   / Assuming battery but thought I'd ask the experts #4
"Tried to jump start it from truck and no luck...."
If your truck engine was running and producing 13+ volts and whatever amperage your alternator is rated at........the tractor should have turned over........unless the ground connections at the battery/starter are corroded/loose.
Yes, check the battery, but check/clean your ground wires.
   / Assuming battery but thought I'd ask the experts #6
I’ve seen batteries so bad or so dead they wouldn’t jump start.
With jumper cables that’s pretty common. I’ve started a completely dead 4bt Cummins with my 2000 amp Noco pack. I’ve never actually tried a 6bt Cummins with that pack but I’ve started a completely dead 6bt Cummins with the 4200 amp Noco.
2007 LUFKIN END DUMP (A58214)
2007 LUFKIN END...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2018 Dorsey Dominator 55-Ton Low Boy Trailer, VIN: 5JYLB5537JPD06956, Honda Gas Engine, Electric (A59076)
2018 Dorsey...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
More info coming soon! (A55787)
More info coming...
toro lawn mower (A56857)
toro lawn mower...
