Assistance with aftermarket loader
   / Assistance with aftermarket loader
One additional comment that might help someone else. I couldn’t get the loader to work after I put in new fluid. The tractor has a front PTO that the pump connects to. I took a closer look at the pump and realized the PTO sleeve was just spinning on the shaft. Whoever put the sleeve on the shaft used just a regular bolt that sheered off. I went and got a grade 8 bolt and and once I got the shaft and sleeve holes lined up, I put that the bolt in the shaft and sleeve with a stop nut.
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
Sedan (A59231)
Sedan (A59231)
