Ashpalt Scratching Solution? Help!
/ Ashpalt Scratching Solution? Help! #1
Nuru
Elite Member
I have a 4310 and i have a Frontier boom mounted blade on the end of my Loader arms]. It has a 72" blade. My problem is that even though the boom mounted blade is highly adjustable, it so heavy that it gouges the asphalt in my Driveway. When i had my 4100, with its frame mounted blade this was really never and issue, but with this boom mounted blade on the 4310, it is an issue. I am looking at trying a rubber edge for the unit to see if that will eliminate the scratching, however that presents another issue when there is a lot of ice on the drive.
Anyone else have any suggestions like - maybe I am doing something wrong with the positioning/adjustment of the loader arms or the blade, maybe both?:eek:
/ Ashpalt Scratching Solution? Help! #2
Is it really "gouging" or just leaving white marks?
Both, but I think i can stopped the gouging, the last outing it was just white marks
/ Ashpalt Scratching Solution? Help! #4
Rather than rubber I'd try a Nylon edge, it will wear to an edge without gouging the drive, rubber will tend to ball up.
Toadhill, who sells nylon plowing edges? Also, the rubber edge I am looking at is 1.5" thick, so you are saying even that will start to ball-up in a while. Nylon does sound pretty good, how is its wear profile?
/ Ashpalt Scratching Solution? Help! #6
Nuru,
Go to TSC and get some horse matting to make an edge with. It will be durable and economical.
/ Ashpalt Scratching Solution? Help! #7
I got mine from a plastic supplier in my area. While I was there I also bought a bunch of scrap Delryn for making bushings. I replaced a bearing on a very old hay wagon when I couldn't get the right bearing for it any longer. It's been in the wagon for many years now with almost no signs ir wear.
The nylon and delryn can be shaped with any normal metal working tools with the exception of a torch.
JDFANATIC said:
Nuru,
I tried that route before and the rubber was too soft compared to the stuff you can get prefabbed.
Thanks TH!
/ Ashpalt Scratching Solution? Help! #11
Last year I used my FEL and Box Blade to clear the driveway. One thing is to never let the BB touch the ashpalt (just use it for weight). The FEL works well but you need to fine tune your skills. I like to relax a little but if your not carefull you can have some problems. The float is not a good option because the bucket fills with snow and pushes the bucket down into the driveway. Adding a strip to my cutting edge would help alot and give me a little room to relax. Let us know how you make out. Replacing a strip every few storms would not be a big deal.
bx24 said:
Nuru-
Check out this other current post for rubber blade ideas and sources on eBay
http://www.tractorbynet.com/forums/owning-operating/112009-snowplow-test-1-a.html#post1281384
Thanks that was a good read. I ordered a rubber blade and it should show up next week. It is 1.5" thick x 72" x 10", and I am gonna drill holes in it and mount my original blade jon top, just like the thread suggested. i was planning on using an over hang of 2 inches, but it seems that 1 inch might work? Based on that thread.:confused:
That is one reason i bought the strip at 10" in height, so I can drill more holes in it as required as the blade wears down.
I know what you mean about the loader, i use the Frontier bioom blade mounted on my loader aarms and that does take some getting used to as ti is so long and if you are not careful the back of the boom will hit and drag along the ground.
/ Ashpalt Scratching Solution? Help! #15
Helped out a few of the people on my road today. The storm we got was ice and snow. The snowblowers did not want to do anything with it. So I used my FEL to clear a few driveways. I did one across the street and I would bet I took a big chunk out of his driveway. After looking I did not but I was a little upset about it. My big problem is in the swale of our driveways. I have to take my time in this area.
The swale is the main reason I would like some strip. Looked at a blade for this year but the FEL does the job for me. Plus all the kids like when I pile up the snow for them.
I have both, but was too chicken to use my loader to move snow sofar, but if we get a lot, I will just switch them back and forth.
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
LOAD OUT AND SHIPPING (A65563)
LOAD OUT AND...
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
5' Bush Hog (A62613)
2015 TIGERCAT 234 LOG LOADER (A64276)
2015 TIGERCAT 234...
