articulated lawn tractor build question
   / articulated lawn tractor build question #11
Ventrac & Steiner use one HST pump to drive both axles so getting the speed the same to both axles is a little easier than two totally separate transaxles.
I suspect getting all of the engine and transaxle controls linked from front to rear will be the biggest challenge.
I have been researching this same topic - just a point on the linking up of controls for frt/rear drives - the old school log skidders use a transfer case to direct drive thru driveshafts to front and rear differentials (I would guess they are of the same drive ratio of course). The driveshaft to the rear uses a constant velocity u-joint configuration to allow for proper flexing without the binding.
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
Toro Three wheeler sand pro (A56857)
Toro Three wheeler...
2020 DRAGON ESP...
Chevy caprice (A55758)
