articulated lawn tractor build question
   / articulated lawn tractor build question #11
Ventrac & Steiner use one HST pump to drive both axles so getting the speed the same to both axles is a little easier than two totally separate transaxles.
I suspect getting all of the engine and transaxle controls linked from front to rear will be the biggest challenge.
I have been researching this same topic - just a point on the linking up of controls for frt/rear drives - the old school log skidders use a transfer case to direct drive thru driveshafts to front and rear differentials (I would guess they are of the same drive ratio of course). The driveshaft to the rear uses a constant velocity u-joint configuration to allow for proper flexing without the binding.
TUGGER TRAILER (A55745)
TUGGER TRAILER...
John Deere 853 20ft Corn Head (A55315)
John Deere 853...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2023 yamaha (A55758)
7021 (A55851)
7021 (A55851)
