Rotary Cutter Article on adjusting rotary cutter (bush hog)
   / Article on adjusting rotary cutter (bush hog) #1
btolle
Platinum Member
Jasper, Texas
Kubota B7510HSD
Ran across a good article on how to adjust the cutting height on a rotary cutter at LSU Ag Center website
As a novice 'bush hog' user it had some good information for me.
Bill Tolle
   / Article on adjusting rotary cutter (bush hog) #2
Bill,
Thanks for the reminder /forums/images/graemlins/tongue.gif… Every now and again I think of setting mine like a finish mower… I know better but the thought still comes around… KennyV.
   / Article on adjusting rotary cutter (bush hog) #3
Good write-up, and also what I do to set my rotary cutter.
Left out the part about adjusting so when the rear of the deck raises the rear wheel off the ground, the PTO shaft doesn't contact the leading edge of the deck. Forgetting to do this properly will (could) result in a bent PTO shaft (I think I came close once, but no damage).
Thanks for the link.
   / Article on adjusting rotary cutter (bush hog) #4
beenthere, I did that and was shocked how expensive those PTO shafts are! /forums/images/graemlins/shocked.gif I suppose I'm lucky I didn't break anything else!
   / Article on adjusting rotary cutter (bush hog) #5
Only problem I have with the article is the way it specified an arbitary minimum cutting height. The RC doesn't know or care what height it's cutting the grass. You know you are cutting too low not by measuring the grass height, but by excessive scalping and/or the skids dragging the ground. Brush is different. It's good to cut brush pretty high to avoid the fatter part of the trunks right near the ground, and excessive re-grinding.
LOT: (2) Komatsu Part # 207-70-73210, (2) Komatsu Part # 208-70-73220 (A59076)
LOT: (2) Komatsu...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2019 Freightliner M2 106 Flatbed Hauler Truck (A55973)
2019 Freightliner...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
TANK MANIFOLD (A58214)
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
