Rotary Cutter Article on adjusting rotary cutter (bush hog)
   / Article on adjusting rotary cutter (bush hog) #1
btolle
Platinum Member
Jasper, Texas
Kubota B7510HSD
Ran across a good article on how to adjust the cutting height on a rotary cutter at LSU Ag Center website
As a novice 'bush hog' user it had some good information for me.
Bill Tolle
   / Article on adjusting rotary cutter (bush hog) #2
Bill,
Thanks for the reminder /forums/images/graemlins/tongue.gif… Every now and again I think of setting mine like a finish mower… I know better but the thought still comes around… KennyV.
   / Article on adjusting rotary cutter (bush hog) #3
Good write-up, and also what I do to set my rotary cutter.
Left out the part about adjusting so when the rear of the deck raises the rear wheel off the ground, the PTO shaft doesn't contact the leading edge of the deck. Forgetting to do this properly will (could) result in a bent PTO shaft (I think I came close once, but no damage).
Thanks for the link.
   / Article on adjusting rotary cutter (bush hog) #4
beenthere, I did that and was shocked how expensive those PTO shafts are! /forums/images/graemlins/shocked.gif I suppose I'm lucky I didn't break anything else!
   / Article on adjusting rotary cutter (bush hog) #5
Only problem I have with the article is the way it specified an arbitary minimum cutting height. The RC doesn't know or care what height it's cutting the grass. You know you are cutting too low not by measuring the grass height, but by excessive scalping and/or the skids dragging the ground. Brush is different. It's good to cut brush pretty high to avoid the fatter part of the trunks right near the ground, and excessive re-grinding.
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
2007 Volvo VNL Truck Tractor (A52748)
2007 Volvo VNL...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
John Deere 7500 Reel Mower (NOT RUNNING) (A50774)
John Deere 7500...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
Skid Steer Quick Attach Jack Hammer (A50515)
Skid Steer Quick...
