Artic Cat 650 Prowler wont start
   / Artic Cat 650 Prowler wont start
I checked the water. It is fine with antifreeze and the fan work also
No I didn't put new jets in it. I just cleaned them out. It has a new spark plug in it.
   / Artic Cat 650 Prowler wont start #13
Ju st trying to get your problem solved. I had a 650 (sold it last week, got a 700) but never had this type of problem. Have you removed your fuel line at the carb and cranked it over to see that it is getting a good supply of fuel. (make sure you have a bottle or something to catch fuel in, dont want a fire) . If you are still getting a good flow of fuel, I would go back and make sure those jets are clean. I had a Kuzma UTV once and I had the carb off three or four times and just couldnt get it to run. Had cleaned it and used compressed air to blow it out. Finally took a strand of very fine wire and worked it through the jets. I think one of them was removable but one was a pressed in one. That solved my problem. Also I dont know if you have found it or not, (hard to locate) but on the side of the carb is a small lever that you can work to self prime it. Try working this lever when you are trying to get it to run. Keep us posted as to what you find and if someone on here cant get you straightned out you can do a Google search of "Artic Cat Fourms". I think there are 3 of them and some pretty knowlegable people on there. Might take a while for some one to responed though.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A57192)
KNOW BEFORE YOU...
V Hydraulic Grain Auger/Hopper Bottom (A56469)
V Hydraulic Grain...
2012 GMC Savana 3500 Passenger Van (A55852)
2012 GMC Savana...
UNUSED FUTURE FT-PDQ 40" LAND LEVELER (A57193)
UNUSED FUTURE...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
JOHN DEERE 450J LGP CRAWLER DOZER (A52707)
JOHN DEERE 450J...
