arps80 hackhoe big thum
   / arps80 hackhoe big thum #1
Army grunt
Platinum Member
Georga
TC 30 Newholland
I have just spent a few days digging with a very well used back hoe ,I see the need for having a big thum for it i have a hy. cylinder from a fisher plow. would this be ok ? also i was looking in northern tool for the right valve any idea witch one i need?
Army Grunt
   / arps80 hackhoe big thum #2
All the fisher plows i've had, had single acting hydraulic cylinders. I'd look at that first because i think you'll need to find a different cylinder.
Ok, I will have a spair one from replacing the swing cilinder. Ill replace the ceals (if i can find a soarse for rebuild kit)
Still in-da-game :)
Army Grunt
   / arps80 hackhoe big thum #4
its alot easier and cheaper to make a ridgid thumb that you can just adjust with a pin, and fold against the boom when not in use. you will have a grand into hoses and a valve likely by the time your done. unless your doing alot of work with the thumb a non hydraulic one works just fine.
2014 Stoughton 28ft Dry Van Trailer (A51692)
2014 Stoughton...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2004 FORD E350 MECHANICS TRUCK (A53426)
2004 FORD E350...
Peterbilt (A51692)
Peterbilt (A51692)
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
