Arm Rests
/ Arm Rests #1
MikeyB
Parker,CO
JD 3320
Hi all,
I have an open station 3320 and got to wondering about armrests after moving snow yet again. I have a bad shoulder and was wondering if arm rests are available?! Does anyone have these and do they help? I looked on JD parts and they do show some in one of the parts diagrams. It looks like a cross piece that would bolt onto the back of the seat and the two arm rests that attach to the cross piece but I'm not sure. It seems this would provide some added security with the seatbelt and the arm rests together. I'm a big believer in the seat belt but that's a whole different story! I have the basic seat and the adjustable ride using a knob in the front (if this helps).
Thanks,
Mike
/ Arm Rests #2
Yes. Your sales person might not be able to find them under the 3x20 options listings though. When I got mine, I had to order them for a 4x20. They only come in black. I would have prefered yellow. You will like them when you are mowing your fields.
/ Arm Rests
Thanks for the reply. Did you order them with the tractor or afterwards? Just wondering if you had to put them on and if so what the kit contained or the dealer installed them when you took delivery of the tractor.
Thanks,
Mike
/ Arm Rests #4
Any chance we can get some up close pictures?
What is the part #?
How much $$$ are we talking?
I would like these on my 4110 if they would fit:D
/ Arm Rests
I looked on JD parts and the back of my 3320 open station seat. On the back of the seat behind the slow moving vehicle sign are four plugs. I pulled the plugs and there are threaded inserts in the seat back. It looked like a possibility so I called the dealer and they came up with a part no. of LVA14483. Looked that up on JD parts and it shows two arm rests and a bracket that bolts onto the seatback. Total cost for kit $192.00:eek: So I am mulling it over! To the guys that have them, are they worth it?
Dealer says I can return the kit if it doesn't work and get my money back if I do decide to order it.
Mike
/ Arm Rests #6
The cab tractors have them and I use them,but mostly only the right side one,my arm is steering on the left side and that one is to low to use with a hand on the wheel. Heres a pic. of the armrests.
minimax
/ Arm Rests #7
Hey MikeyB,
Why don't you just "MAN UP"? It is a tractor after all.
/ Arm Rests
Zipperhead0 said:
Hey MikeyB,
Says the guy who bought a new tractor just cause the seat on his Kubota hurt his "sensitive areas down yonder!":D
Mike
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2023 Peterbilt 567...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
ROLLS OF CHAIN LINK FENCE (A64281)
ROLLS OF CHAIN...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
