Arians 22 ton log splitter qustion
   / Arians 22 ton log splitter qustion #1
jack707
up North wisconsin
farm trac 555
I think the carb. On this splitter is bad has anybody had a problem with these. And it's just over a year old and they don't cover fuel problems either!.
   / Arians 22 ton log splitter qustion #2
I don't have an Ariens log spliter but we do have Ariens lawn tractors, I have had to take the carbs apart about once a year and clean them with Honda carb cleaner, ethenol is bad stuff..
   / Arians 22 ton log splitter qustion #3
No problems with mine, but then I always run the tank and carb dry at the end of the day before I put it away, and always use E0 non-alcohol fuel.
   / Arians 22 ton log splitter qustion #4
Try running some Seafoam through it.
I waited awhile and it started on the first pull. I cleaned the carb. With breke clean and wiped it down with a rag and took out the screw on the bowl on the carb and let the gas run out, it seemed to work . I use 91 on the splitter and chainsaw.
I think I need a new carb. on it because it just don't sound right.
CATERPILLAR 126" PIN ON BUCKET (A52707)
CATERPILLAR 126"...
Informational Lot - Shipping (A55314)
Informational Lot...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
1999 Southwind Fleetwood 34N 34ft Class A Motorhome (A55853)
1999 Southwind...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
