Arians 22 ton log splitter qustion
   / Arians 22 ton log splitter qustion #1
jack707
up North wisconsin
farm trac 555
I think the carb. On this splitter is bad has anybody had a problem with these. And it's just over a year old and they don't cover fuel problems either!.
   / Arians 22 ton log splitter qustion #2
I don't have an Ariens log spliter but we do have Ariens lawn tractors, I have had to take the carbs apart about once a year and clean them with Honda carb cleaner, ethenol is bad stuff..
   / Arians 22 ton log splitter qustion #3
No problems with mine, but then I always run the tank and carb dry at the end of the day before I put it away, and always use E0 non-alcohol fuel.
   / Arians 22 ton log splitter qustion #4
Try running some Seafoam through it.
I waited awhile and it started on the first pull. I cleaned the carb. With breke clean and wiped it down with a rag and took out the screw on the bowl on the carb and let the gas run out, it seemed to work . I use 91 on the splitter and chainsaw.
I think I need a new carb. on it because it just don't sound right.
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
Cushman Electric Cart (A55853)
Cushman Electric...
2003 Big Tex 10PI...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
