Are there special angled washers to use to bolt angled "C" channel steel.
   / Are there special angled washers to use to bolt angled "C" channel steel. #11
Wedge washers. That are square shaped. We use them at my work for m12 bolts. Work good. Sometimes you need to grab the washers with pliers to keep it from spinning .
   / Are there special angled washers to use to bolt angled "C" channel steel. #12
Re: Are there special angled washers to use to bolt angled "C" channel steel.
If you need only a few tapered washers and have a scrap piece of channel. Cut the flange off and drill holes in it to make washers.
Now that is a good idea if you only need a few.
They made a bunch of 3/4" x 6" HDG lags for us not too long ago. The lags were not available as stock items from anyone, and we needed thousands. The picture below shows one of the bulk boxes we received
That is a crap load of lag bolts, what were they used for if you don't mind me asking, I wouldn't want to be the poor guy driving them all :)...Mike
I need 10 of those washers---1/2"--so it's too many to make by hand. I'll try the trailer hitch installer first. Thanks for that tip.
   / Are there special angled washers to use to bolt angled "C" channel steel. #14
..................That is a crap load of lag bolts, what were they used for if you don't mind me asking, I wouldn't want to be the poor guy driving them all :)...Mike
We are mounting equipment to railroad ties.
   / Are there special angled washers to use to bolt angled "C" channel steel. #15
MCmaster Carr has wedge washers
McMaster-Carr
   / Are there special angled washers to use to bolt angled "C" channel steel. #16
Standard accessories attached to truck frames are attached using "U" Bolts or All-thread and plates.
Drilling through the channel flange will weaken it!
Drilling through a 6" channel flange on a hot rod grocery getter pickup will be fine.
Caterpillar 725 Off-Road Dump Truck (A57453)
Caterpillar 725...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
Sign Board (A56857)
Sign Board (A56857)
3PT BOOM POLE (A52708)
Kubota L4701 (A53317)
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
