Are the BX tractors top heavy and tippy?
   / Are the BX tractors top heavy and tippy? #11
I have the spacers and love them for two reasons: The obvious one is that baby feels more stable on uneven ground; the second reason is that the spacers make installing snow chains incredibly easier!!
   / Are the BX tractors top heavy and tippy? #12
I have had a BX2200 and now a BX2660 and mow hills, pond levies etc., both have been very stable with no need for spacers.
   / Are the BX tractors top heavy and tippy? #13
Top heavy and tippy? That's completely not true. Just look at the thing; it's low and squat. It has a low center of gravity and is more stable than most other tractors.
:thumbsup:
Don't know how anyone could make a lower center of gravity machine.
Nothing wrong with buying spacers, I suppose, especially for chains, but the marketing hutzpah of that outfit is pretty suspect.
   / Are the BX tractors top heavy and tippy? #14
I am a bit surprised that the response wasn't a bit more mixed. My BX23 doesn't have spacers and the tires are not loaded either. So far I have not tipped it over, but it has been on two wheels a few different times.
I live on ten, very irregular acres lots of dips and bumps. The ROPS is always up and any time I am off the smoother areas, the seat belt is buckled up.
I do love the tractor and for most normal use, the tractor is quite stable. One of these days I may put a pair of wheel spacers on it, but then I might get over confident.
You do make a good point here. The strength of the FEL and the BH in relation to the weight of the tractor itself are such that it is indeed possible to get tipsy under certain conditions. Put too much weight in the FEL (especially with no counterbalast on the back), lift it too high during transport, drive on a grade while turning with an overloaded FEL and I guarantee you will have wheels coming off the ground. I have done that more times than I care to think about. It can lead to scooting your body in the opposite direction trying to prevent a roll concurrent with considerably increased cardiac activity. If those are going to be your (the O.P.'s) operating conditions, then by all means, buy the spacers.
gwdixon makes a good point as well. The same squatness and small wheels that give the low center of gravity create a tradeoff of very low ground clearance.
   / Are the BX tractors top heavy and tippy? #15
You will love this little brat from ferrari Tractor in California.:thumbsup:
   / Are the BX tractors top heavy and tippy? #16
All of my BX work is hillside work... the nature of the Subcompacts is they have a narrow stance which allows them to access places larger tractors can't.
Part of operating any piece of equipment is knowing it's limitations... a good operator will take into account terrain, loading and balance at all times.
I had my rear tires foamed filled because too many weekend plans were cancelled by flats... as an extra bonus, the foam added significant weight down low and noticeably improved stability.
   / Are the BX tractors top heavy and tippy? #17
BX2200, BX1500 (already counted), BX2350, and BX2660,,,,,,,,NO but I have gotten some of them up on less than 4 wheels but it was me and not the BX's fault. My current BX25 with the BH doesn't feel as stable as the others without BH but that may be in my mind but I am more careful with it. BX1500 with MMM only seemed glued to the ground and next was the BX2350 MMM only. Add the FEL and gets a bit more tippy feeling and then add the BH and seems even a bit more tippy. Any BX with MMM only are tight to the ground, in my opinion/experience. I also have gullied, hillside rocky treed property.
   / Are the BX tractors top heavy and tippy? #18
A website that sells wheel spacers for the BX series tractors (thetrackscompany.com) says that the BX tractors are "top heavy and tippy". What are your thoughts on this matter?
I have a BX 25, and before I installed spacers I would only go straight up and down hills when the FEL and BH were attached. The BH in the upright folded position made it feel too "tippy" for my liking. My dealer actually recommended rotating the BH to the uphill side to help compensate for the feeling.
I installed 2" spacers on the rear only, and the difference was remarkable. I can now navigate on almost all of my property without the pucker factor kicking in. Additionally, the 2" still allows use of my MMM which is a 60" model. With FEL and BH removed, I can take my machine nearly anywhere.
I would recommend spacers in any situation when hills are involved.
   / Are the BX tractors top heavy and tippy? #19
JohnThomas and others nailed it. Big difference between BX only and BX + FEL and BH. The FEL and BH add a lot of weight up high. Spacers help if needed, but the BX by itself is quite stable compared to some of the slightly larger CUT's with taller wheels. Saw an older Mitsubishi CUT at an auction... narrow, high and no ROPS! Probably a good little tractor otherwise, but no thanks!
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2025 JMR 40in Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
