are hydraulic fittings reverse thread?
   / are hydraulic fittings reverse thread? #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
going to be adding a diverter for a 3rd function, some of the fittings on my max 26 have a notch on the couplers. before i go break 700 dollar lines, are any of these lines in general left hand thread?
   / are hydraulic fittings reverse thread? #2
I've never heard of LH threads on hydraulic lines.
What/where is the notch? Picture?
on the nut itself, single notch, I know most left hand are 2 notches, just double checking, no photo right now
   / are hydraulic fittings reverse thread? #4
Is the notch on the quick disconnects? If yes I have seen that and they were not LH thread.
   / are hydraulic fittings reverse thread? #5
Forty years with tractors and related hydraulics. Never seen LH threads. Always - righty tighty, lefty loosey.
thanks everyone
   / are hydraulic fittings reverse thread? #7
All my flat face couplers have a notch on the release ring. Is that what you're talking about? It needs to line up with the pin/ball to release the coupler. The release ring will rotate so you can lock a coupler together if necessary.
48 Inch Farm Jack (A57454)
48 Inch Farm Jack...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
(31) Concrete Pins (A57454)
(31) Concrete Pins...
Case 930 Tractor (A59814)
Case 930 Tractor...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
