Are ATV's Morphing into Tractors?
   / Are ATV's Morphing into Tractors? #1
have_blue
Veteran Member
Eunice, Louisiana
L4400
I think ATV's are rapidly morphing into tractors. Am I wrong?
If you think about how ATV's started out as sqirrely 3 wheelers, to 4WD, to side-by-sides with canopies, to power steering, to the proliferation of small implements, it looks like the classic 80 year old cast iron tractor configuration is going to have competition. (I'm referring to ~45hp and smaller CUT's, not big ag tractors.)
Take a basic ATV design, make the frame bigger and heavier, tires larger, add diesel, a PTO (not integrated with the engine or transmission PLEASE!)and you have a serviceable CUT. There would have to be a way to temporarily firm up or lock the suspension for lifting implements and FEL, but that's a small detail.
I like the thought of a soft suspension to speed up mowing, and not having to split the whole tractor in two just to work on a clutch or seal. :D
   / Are ATV's Morphing into Tractors? #2
Take a look at Bobcat's "Toolcat" on their web page. It is exactly what you describe - an ATV/tractor morph. And they look mightly comfortable!
Mike
   / Are ATV's Morphing into Tractors? #3
The primary issue is weight. They simply don't have the weight needed for ground engaging implements.
   / Are ATV's Morphing into Tractors? #4
Some are trying to use ATV/RUV vehicles as tractors and for light work like food plots and snow removal they seem to be OK. I have a 700 Grizzly and 660 Rhino and while very handy suck at doing any real work. I might be interested in an "up armored" ATV for some things as a supplement to a tractor, but would hate to even think of the cost.
   / Are ATV's Morphing into Tractors? #5
Its been done!;) Check out the Yamaha TerraPro. Was ahead of its time for sure. THey didnt sell a whole lot of them, and the ones that are around demand a pretty penny considering they were only made in 1988.
Yamaha Motor Corporation, USA - 1988 Terra-Pro Home
   / Are ATV's Morphing into Tractors? #6
Mike
Went there and checked it out. Very useful machine that definately makes the cross over.
   / Are ATV's Morphing into Tractors? #7
It's only 349cc. It would have to be spinning awfully fast to make enough power to make it useful for mowing, tilling etc. I don't think I'd want to have to listen to it.
   / Are ATV's Morphing into Tractors? #8
Willys wanted the Jeep to morph into a tractor (see our Web site) and they had some success. Like you, I've watched ATV's change and if I didn't already own 3 jeeps, I'd have one for the farm. Come to think of it, maybe the ATV is set to become the new "farm jeep."
   / Are ATV's Morphing into Tractors? #9
A bit off topic, but it's another type of tractor. In fact, they're called road tractors. You can still buy some nice used ones (under $10K), and even a newer one ($150K+) !!
Check out this old brochure... I don't think there's another tractor out there with this versatility.
http://vonsmog.com/images/caseunimogbrochure.pdf
I read once that they can pull 300,000 lbs. (I wouldn't try it.)
Mike
I knew Bobcat was making (or re-labeling and selling) tractors, but had never heard of the Toolcat. Very cool, just about what I'm talking about.
I've been thinking for years that 45hp and smaller tractors are handicapping their customers by using the ancient casting configuration that the big tractors have.
Someone mentioned weight. By the time you drop in a 30-45hp diesel, add 4 large wheels, and beef up everything, weight need not be a problem!
The main problem I see is adding a 3 point hitch, but hey, maybe it's time to bury that too. There should be better ways to mount equipment in this day and age.
set of 4 tractor trailer tires Roadforce (A56438)
set of 4 tractor...
2000 Volvo Semi (A59814)
2000 Volvo Semi...
Adams 16T Tender Body (A56438)
Adams 16T Tender...
2019 Grove TMS 9000-2 115 Ton Hydraulic Truck Crane (A60460)
2019 Grove TMS...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
