Architectural design software
/ Architectural design software #1
Furu
I have a software program called "Punch! Home Design Architectural Series 3000" that I have been using since 2009. It has done what I needed and I never updated it so it is OLD and out of date. I have a barn design that has to go through engineering and truss design and they have asked for a cross-section plan-view of my barn/shop plans and I can't get that from the program I have.
Does anyone have a design program that they use that does not have TOO steep of a learning curve that will provide cross-section views as well as the floor plans that are created?
/ Architectural design software #2
I use FreeCAD for this type of work. You built the 3D model of the building, then take the views into the drawing. Sectionals can be made by picking a view and using the section tool.
FreeCAD is a WorkBench based software. If you understand how WorkBench method uses modules, then the learning curve is easy. This is not SolidWorks nor Alibre nor Inventor. And FreeCAD is 100% FREE.
/ Architectural design software #3
and now, how to take the 3D building to a 2D drawing with views and sections.
/ Architectural design software #4
FreeCAD also does gears, plastic parts, etc like any major CAD software does.
Need to replicate and re-make tractor parts ?
3D model the 4WD gears and shafts to be re-made at your local machine shop easily.
or
3D print dash panels, emblems, etc.
/ Architectural design software #5
I have used the below to design our new home. Pretty easy to learn! You can download a trial version. Crazy how powerful the software is.
/ Architectural design software #6
Check this one out instead as it also includes non profession software at a pretty low cost.
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2015 Nissan Leaf Hatchback (A61574)
2015 Nissan Leaf...
2021 Caterpillar 302.7 (A64126)
2021 Caterpillar...
2022 EZ-GO ELITE...
2010 Cadillac CTS Sedan (A61574)
2010 Cadillac CTS...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
