Architectural design software
/ Architectural design software #1
Furu
I have a software program called "Punch! Home Design Architectural Series 3000" that I have been using since 2009. It has done what I needed and I never updated it so it is OLD and out of date. I have a barn design that has to go through engineering and truss design and they have asked for a cross-section plan-view of my barn/shop plans and I can't get that from the program I have.
Does anyone have a design program that they use that does not have TOO steep of a learning curve that will provide cross-section views as well as the floor plans that are created?
/ Architectural design software #2
I use FreeCAD for this type of work. You built the 3D model of the building, then take the views into the drawing. Sectionals can be made by picking a view and using the section tool.
FreeCAD is a WorkBench based software. If you understand how WorkBench method uses modules, then the learning curve is easy. This is not SolidWorks nor Alibre nor Inventor. And FreeCAD is 100% FREE.
/ Architectural design software #3
and now, how to take the 3D building to a 2D drawing with views and sections.
/ Architectural design software #4
FreeCAD also does gears, plastic parts, etc like any major CAD software does.
Need to replicate and re-make tractor parts ?
3D model the 4WD gears and shafts to be re-made at your local machine shop easily.
or
3D print dash panels, emblems, etc.
/ Architectural design software #5
I have used the below to design our new home. Pretty easy to learn! You can download a trial version. Crazy how powerful the software is.
/ Architectural design software #6
Check this one out instead as it also includes non profession software at a pretty low cost.
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
2023 Case TV380 (A62177)
2023 Case TV380...
New Holland TC21 (A62177)
New Holland TC21...
