Anyone with the new 425...
   / Anyone with the new 425... #21
I put one on my Robin's after i flooded the crankcase with gas, and kept it with the re-engined kohler.
I had to put one on my 1430 too. I used it a couple times to clean out the primary fuel filter when I first bought the machine.
   / Anyone with the new 425... #22
Just read this post - sorry for not sharing the pics right away but Moss was johnny-on-the-spot.
I'll say one thing about the muffler - it gets hot quickly! I'm used to warming engines up prior to changing oil to stir up whatever gunk/metal might be in there and get it out with the oil. The oil filter is directly behind and under that exhaust pipe. When trying to remove the oil filter in that tight space, it's pretty easy for a guy to accidentally just press a part of their arm against it.......took a couple of weeks for the scabbing to clear.:mad: I now change the oil after a very brief warm up period.
Separate issue related to the exhaust - I started hearing this rattling noise and discovered that the bolts were missing from one of cylinders where the exhaust manifold mounts to the engine. The other cylinder was ok but it caused the whole assembly to get loose and rattle. Replaced the bolts, re-secured, and all was well. Probably not a systemic problem.
I actually do use the fuel shut off regularly. It's easily accessible and you don't need to tilt the seat or lift the tub cover all the way to turn on or off. I read too many accounts of flooded engines.
   / Anyone with the new 425... #23
Does this Kohler engine backfire when you shut it off after the engine is warmed up? The 425 I had used to backfire. I thought the sound of the muffer was nice, it was also fairly quiet.
Yeah, I used the fuel shut-off valve allot on the 425 I had too. Mostly for changing out the fuel filter. This Duetz engine has two fuel filters. The primary one catches the big debris and the secondary gets the fine particles ( I assume.)
   / Anyone with the new 425... #24
yup, it backfires when shutting off. The hotter it is, the bigger the backfire. Throttling down prior to shutting it off helps.
   / Anyone with the new 425... #25
My 2001 model 425 never backfires when I shut down. I've had several other small engines that did, but not this one.
   / Anyone with the new 425... #26
I have no idea what's inside that muffle box marked "HOT". Could be empty as far as I know but maybe that's what leads to the backfire. No harm as far as I can tell but kinda embarrassing when someone's there to witness. Reminds me of Jethro from that Beverly Hillbilly show.
   / Anyone with the new 425... #27
ya, that's right, I read the "HOT" and still burned my arm so maybe I am Jethro:)
   / Anyone with the new 425... #28
Incline...any chance you can take a few pictures of your hydraulic pumps? I'd really like to know if PT is still using the Bondioli and Pavesi pump with the Kohler engine. Thank you.
   / Anyone with the new 425... #30
Here you go - It appears they are B&P pumps based on the stamped logo. A couple of stamped numbers as well if it helps:
128051900
P162X19 followed by 2600
P139X1
These pumps look nothing like the ones depicted in my owners manual but here they are.
   / Anyone with the new 425... #31
From the one picture I can see that they started using a different sealant on the gasket in between the two separate pumps. They used to use some kind of shellac sealant, in which mine leaked. So, they gave me another seal that I put on, and it still leaked a drop at the bottom every now and then. Nothing worth worrying about.
Thank you Incline.
Yes, this is a Bondioli and Pavesi pump. It's probably a 19 cc HP P2. Recently, the 425 used a 21 cc M4PV and the 1430 used a 28 cc M4PV I believe. Some older 425's used a 19 cc NT10 with an aluminum pump casing. That pump is no longer in production.
So...what's the difference between an HP P2 and M4PV besides displacement? No idea. It's possible the "P" series is a later design because there's a wide displacement range in this series.
   / Anyone with the new 425... #33
marrt - so you were making some comments about new model 425's having case drains on the wheel motors. Apparently mine has a return line that I wasn't even aware of.
Does this line flow enough oil from the wheel motors back to the tank to completely flush out the wheel motor system regularly?
You may recall sometime back that there was some discussion about the fact that the wheel motors were on a "closed" system and wouldn't receive fresh oil even if the main tank were changed out. Wondering if this changes that?
Hi Andy,
This short answer is...maybe. If the case drain is installed primarily to deal with normal leakage, as opposed to cooling for example, then the leakage should be minimal on a newer machine. In fact, one of the ways to test a pump or motor's condition is to measure this leakage and compare against a stated standard for the pump or motor.
However, there are a lot of unknowns in our case. What is the volume of the leakage? What are the particle sizes that can move past the motor's internal tolerances and end up in the return line? What is the total capacity of the closed loop circuit? What is the volume of the variable displacement pump leakage? Etc...
As a general rule, I would say these case drains do help to swap out the oil in the closed motor pump loop over time. However, the greatest benefit, as mentioned earlier, has to do with long-term reliability of the motor seals.
I hate to keep asking for more pictures, but could you take a picture of the back of one of the front wheel motors where the hoses connect? I'm curious to see if this connection point is an option offered by the wheel motor manufacturer, or is a modification made by Power-Trac (which I suspect).
Tom
   / Anyone with the new 425... #35
Here you go.
I'm not convinced this wheel motor is the White CE 14.3 that folks on here generally refer to as the "larger wheel motors" (compared to 15-20 year old 425's). The back doesn't say Roller Stator, the bolts are not recessed, and obviously it now is end ported either by the manufacturer or by powertrac.
Curious what your thoughts are.
Thank you for the pictures. Yes, this is a somewhat unique motor for a PT. It's using a square mount but with holes capped for the hydraulic ports. Also, it appears there's a number ending in "CE" on the motor mount? I assume it's still a tapered shaft. The end porting is an option for some Danfoss (White) motors. Because the end cap has cast lettering, this is not a PT fabricated end cap. It also looks like it may have medium duty bearings. I'm convinced this motor has been spec'd by PT. My only question...is this a custom OEM assembly (i.e., not readily available for retail purchase) or can we find the exact specification. So far, I've not found a way to spec this exact motor on Danfoss's website.
I notice the parking brake plate is now bolted on. Not sure why but it can be removed if not needed...and to stop the "clicking" from the pin rubbing. I redesigned my parking brake (actually, a friend did) and it's much better now. I need to post some pictures.
I'm always trying to figure this stuff out not because I don't like paying PT's high prices on parts. Personally, I've got no problem with their pricing because it comes with free tech support from Terry (plus, if you think their prices are high, try buying some stuff for a Bobcat or Takeuchi). I want to know what's in these machines because I'm curious. Plus, if I want to upgrade something (like I recently upgraded my 14.2 cu. in. wheel motors to 22.8 cu. in.), then PT doesn't offer this option and I need to know what to order. In addition, there's no guarantee PT will be around forever and, since they mostly use off the shelf parts, I want to know what's in my machine.
   / Anyone with the new 425... #37
I haven't been able to find any pictures of wheel motors like this either but there's a ton of 'em. No "CE" markings that I could see. There were these stamped numbers but they didn't lead me to any particular motor.
35713
4474544 - Google reveals that this is a patent # assigned to White Hydraulics
6321
One day I'll just call up PT and ask them. Mostly I was curious where it sat in the power spectrum.
   / Anyone with the new 425... #38
Here you go.
View attachment 619334View attachment 619335View attachment 619336
While we are somewhat on the subject and I just want to learn about these, what does the Roller Stator signify?
As far as I know, this is a brand name. It's probably a play on words from the electric motor world (Rotor/Stator). This motor is likely a gerotor design which is common for small high torque, low speed motors.
For even more torque, the next step might be a fixed displacement piston motor. And for even more torque, add a planetary gear set. For example, a tracked machine will often use a hydraulic motor coupled with a planetary gear set to drive the tracks.
2014 Freightliner Bucket Truck (A61306)
2014 Freightliner...
iDrive TDS-2010H...
2011 Toro Multi Pro 1250 Sprayer Cart (A59228)
2011 Toro Multi...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
