Front-End Loader Anyone used a Markham back hoe (on FEL)?
   / Anyone used a Markham back hoe (on FEL)? #1
HCJ
upstate South Carolina
Kubota M6800 4WD
Happened to see on Markhams Welding website a "back hoe" that mounts on a QA FEL. Obviously, this is a limited use implement but was curious if anyone has any knowledge of this. I saw a previous reference to a "Quick Spade" but this actually has a bucket that curls. A real backhoe is unfortunately years away in the toy budget, so when I need to dig, I reach for a shovel. Needless to say, I don't dig much.
   / Anyone used a Markham back hoe (on FEL)? #2
What's that ?
   / Anyone used a Markham back hoe (on FEL)? #3
One of those SSL backhoes would tear your FEL to shreds I am afraid...Just because you have a universal SS QA setup does not mean you can attach any SSL attachment.
thanks for the info. I just ordered my loader amd was just dreaming about what could be done with the QA attachment.
   / Anyone used a Markham back hoe (on FEL)? #5
Agreeing with Kenny. A Bobcat brand backhoe also attaches to heavy hook brackets (similar to how a FEL attaches to a tractor) on each side of the machine, welded to the fenders, which are really part of the frame. The QA portion is only a small part of what holds the BH to the Bobcat.
jp
   / Anyone used a Markham back hoe (on FEL)? #6
For a CUT, I only see these basic options:
Bucket
Grapple
Forks
Hydraulic PHD
How does the performance of the hydraulic PHD compare to the 3-pt. hitch model? What hydraulics do you need to run an average size unit? I understand that you cannot run one off of the electric over hydraulic valve. Do you power it off of the back? I just built a pole barn and had a friend bore holes with his skid steer. Are the PHD the same, in other words, could I borrow his and attach it to my FEL assuming it's of average size?
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2021 Chevrolet Colorado Crew Cab 4WD Pickup Truck (A55852)
2021 Chevrolet...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A55314)
2023 Unverferth...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
