Ballast Anyone Use Bar Bells as Rear Wheel Weights????????
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #21
I only put the 250lb of wheel weight on to help with traction when using a front blade or front blower. When using the FEL (or forks), I put another 900lb weight on the 3-pt.
In general, I would think that you would want to add approximately 1/2 of your loader rating to the rear of the tractor. For example, if the loader is rated for 2500 lbs, you would want to put about 1000 to 1500 on the back in some combination of the 3-pt, in the tires, or on the wheels.
- Rick
Wow!!?? Half of the loader rating? I assume that some of you have weights mounted on the 3-point hitch to meet this.
To continue....How do you mount weight on the 3-point?
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #23
Hi...
EZ Weight supports...
Yeah... the standard barbell weight plates fit over the 1" rod just perfectly... /forums/images/graemlins/smile.gif
Now I gotta' get (60) 1/2" washers to shim out the 6 support brackets away from the wheel to make it fit right...
Dave...
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #24
I asked the question (think it was under the Kubota owning/operating section) about what people use as rear wheel weights. Got lots of replies and some nice pictures of gizmos that hold cheap weights on the wheels.
Just go back a ways or use "weight" in the search area.
Ralph
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #25
EZ Weight hardware installed...
Easy enough job...
(3) 50 lb barbell plates on each wheel... room for 1 or 2 more on each wheel...
Photo 1 attached...
Dave...
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #26
Photo 2...
Dave...
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #27
Photo 3...
Dave...
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #28
I'm trying to figure out your setup.... /forums/images/graemlins/confused.gif
Did you get 2" hole-diameter plate and have to make some sort of filler...?
And I can't figure out what the black pipe is at the end of the threaded part...
Mark
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #29
Dave, I am interested in the guard around your valve stem. Did the rim come that way or did you add it? I looks like it is welded on. I broke a valve stem while clearing brush and would like to prevent that from occuring again.
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #30
Hi...
Standard barbell plates with 1+" diameter center hole fit over 1" diameter center rod...
Black " thing" on the end is black rubber pipe insulation fit over the 1" rod as a protection cushion...
Dave...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
New/Unused Quick Attach Post Driver (A54865)
New/Unused Quick...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
Wolverine 86in Quick Attach Tiller (A54865)
Wolverine 86in...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
