Snow Anyone use a snow thrower on their 3000 series cub
   / Anyone use a snow thrower on their 3000 series cub #11
I live a couple of miles from Lake Michigan and we can get dumped on with snow. I started with a walk-behind blower and in the 70's got a Snapper. When it got tired, I looked for a new tractor, lawn mower, snowblower. I almost bought a used JD when I found this deal on the Cub, new and not much more money.
I can remove the bumper and install the lift frame in a few minutes. It takes as much time to find the right wrenches as it does to remove the 2 bolts for the bumper and install the lift with its 6 bolts. I wipe off the hose connecters, one male and one female, and snap them into the tractor connectors. I can't mix them up. I can mow lawn or pick up leaves with the lift attached.
When I need the blower, I remove the mower deck for ground clearence, I drive up to the blower and attach the PTO shaft. The PTO shaft slides for length changes and this gives me room for my hands to opperate the coupler. I drive forward another inch or two aligning the 2 pins with the "V"'s on the lift, raise the lift and the blower, twist the lower snap pins on the lift to engage the holes in the blower and am ready to move snow. This takes more time to write about than to do. The lift has flareds sides so as you move to the blower it is somewhat self aligning. Nice design touch.
The whole unit seems well designed. The 2 stage gets the snow far enough away from the drive I don't get banks I can't throw over. The quality seem good even the paint held up better than I expected. (Road salt. scratches, etc.) It is big and can move a lot of snow. The weight and large rotors keep it from wanting to climb up and over the snow. I have had it happen under the right snow conditions that it freeze up when sitting in the barn. Wet snow would freeze the 2nd stage impeller. Removing the slop after turning off the tractor keeps this from happening. It has never happened while using the blower and I have used the blower to remove slush I didn't want to freeze in the drive. I am happy with the unit.
chuck,
I cant thank you enough on all the details regarding the Snow thrower attachment for our Cubs !! It is kind of hard to buy something sight unseen, so I had to be sure. My thrower just came in at the dealers, so I will drop it off soon for the setup.
I still have many weeks more of mowing as I will detach and re-attach mower. Not a lot of people have Cubs 3000 and thrower setups. I'm sure its the expense, so the information you gave me was really key !! I have an older Cub 125 with a single stage thrower which always works great. I have to loan it to "family" this winter in NH, to help them out. I'm ok with that because the 3204 was its intended replacement. The other option was to get the thrower for my JD 4100. The price on that unit was really high (4k approx). I'm real happy that I made the wiser move w/ the thrower for the 3000 series. Your feedback was very instrumental !!
Thanks again,
Joseph /forums/images/graemlins/smile.gif
Completed Blower, Chains & weights on my 3204....just need the snow ( i hope it snows this year /forums/images/graemlins/blush.gif )
   / Anyone use a snow thrower on their 3000 series cub #14
I've got a Cub 1862, which is about 9 or 10 years old so it was built prior to the 3000 series, but is still very similar in size (mine has an 18hp Kohler). I use a 48" blower on the front of it, with wheel weights and chains, so the set up is very similar. The blower has a front mount that is also similar but is belt driven. I used it to clear our drive for 8 winters without any real problems except for one broken shear pin when I accidently found the garden hose that I forgot to put away before a surprise snow storm buried it. Anyway, it takes a lot longer to put the blower on the Cub than it does to install one on the back of a CUT with a 3pt hitch, however it works very well and I am very satisfied with the unit.
Hi Bob,
I know that model well !! actually around the same time I was
attempting to buy a 1863 model (same model basically) very well built unit. I'm looking at the original quote I had for all the accessories from back then ! The deal fell apart and I decided to put more time into my older 125. This year I got the 3204, and decided to get serious!! They made things real easy for install and removal. No more carraiges to install, or any belts...direct drive shaft w/ couplers only. 6 bolts and I have the Hydro lift on, and drive up to the thrower. It has self alignment, and locks into place, last thing connect drive shaft..
15 minutes and you are ready for snow! no Joke...huge improvement over my 125...
Happy snow blowing either way !! I'm looking forward to it!!
Duc
   / Anyone use a snow thrower on their 3000 series cub #16
It should take about the same time to mount either one Bob. That's not including removing the mower of coarse.
   / Anyone use a snow thrower on their 3000 series cub #18
How about a blade? How well does it work at pushing snow with a 3204? We've got a gravel drive, and it will beat the heck out of even the toughest snow blower. Or, can snow blowers for this tractor be set high enough to avoid the gravel?
Gravel driveways are a snow blowers arch enemy...there are many methods to make it work ( have a base of snow on top of gravel) The skid shoes, and since it is Hydraulic lift, you have
an infinite range between the two limits...cant speak how well a blade works on this machine, but it has the weight and hydro angling so it may do very well
2014 Ram 1500 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 Crew...
Wacker Neuson Roller Parts (A47477)
Wacker Neuson...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
2006 FORD F-350 (A53422)
2006 FORD F-350...
Year: 2012 Make: Audi Model: Q7 Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 161335 Plate: B... (A55853)
Year: 2012 Make...
2018 Altec DC1317 Towable Brush Chipper (A55787)
2018 Altec DC1317...
