Anyone use a Cant
/ Anyone use a Cant #21
My peavey goes in the loader bucket every time I'm getting serious wood hauled out or cut. Great for rolling stubborn stuff, or simply getting leverage where you need it. I keep threatening to add two steel loops on the loader upright to hold it in place.
The wood handle is better in my opinion, your fingers and wet gloves won't freeze to it in January. I'm a fair big boy, haven't broken mine yet, or even come close. Mine's older than dirt, the old man had it before I was around, as far as I know.
Sean
/ Anyone use a Cant #22
Mine are used on the beach and it seems like after @10 years they get a little rot right where the wood goes into the metal. They always go into the shop when not in use but get wet with saltwater every use, maybe that's y:confused::confused:
Rick
/ Anyone use a Cant #23
I have a small cant hook that has about a 3' handle that I use while cutting wood, comes in real handy when cutting on the ground. I can cut almost through all the way down the log and then roll it over with the cant hook and finish the cuts without getting in the dirt.
/ Anyone use a Cant #24
I have one of those high dollar 5' blue Log Rite cant hooks.
They work ok, but I actually bent mine trying to twist loose a hung up cedar tree; and I only weigh 160#.
They have a lifetime warranty, but I was in the middle of logging lumber for my house and didn't want to take the time to return it.
I understand that they make stouter model now.
I guess I should return it now that I'm not currently using it and see what they'll do about it.
/ Anyone use a Cant
Funny thing is their website doesn't show the heavy duty models. I have seen them on other websites. I even found that if you add a "x" before the part number it brings up the page of the tool.
Cant Hook 60"
Xtreme Duty Cant Hook
Go figure.
/ Anyone use a Cant #26
I too have several of them made by peavy manuf. in Bangor but the one I use the most is made of 1" pipe, keep it right on the winch behind the tractor and use it often. I broke a wood handle years ago (ran over it with a twitch of wood) and used the hook to build the pipe one and it has never failed me. It has been bent and straigtened (ran over it too, Father always said sharp as a tack and twice as flat headed).
/ Anyone use a Cant #27
I'd like to get a cant hook for dragging, but what I do is pick up one end of the load with my FEL and throw a chain around it. If I want to cut in place, I'll pick up an end as described and put a log or something under it, then drop the log. One end will be cantilevered so I can lop off rounds without having to roll it.
My peavy is used for rolling logs to complete cuts (when the log is on the ground) and moving really big stuff onto my vertical splitter.
I've got an old log (cedar I think) I just excavated from the brush around it. it's possibly 5 feet in diameter and about 30 feet long. not sure HOW I'll handle that one!
/ Anyone use a Cant #29
Johnbro, have you thought about milling it up?
Cedar sure has better uses than firewood.
Rick
I'm not sure what I'll do with it. It's been on the ground for at least 10 years and probably lots more. Problem is it's too big to move and I'd have to cut down a tree and dig out a big stump to get at it for milling. I think I'll borrow my buddy's big saw and cut the end off to see what's in there... If it's good cedar I know a guy with a mill and maybe we could get some wood out of it.
/ Anyone use a Cant #30
There are chainsaw carvers around looking for such a prize. Might be worth checking them out if at all interested in its value.
/ Anyone use a Cant
Ceder should last just fine. My neighbor has a shake machine that's got to be about 100 years old but works great. It's just a little less safe than what's made today. It's got an 48" circular blade, an automatic system to increment the log to cut it at the right taper (actually can do different cuts with a change of a die), and a planing wheel to square up the sides. All you need is a leather belt and a tractor or large motor. He would die for a log of that size to make shakes out of.
/ Anyone use a Cant #32
There are plenty of us around with saws that would love to chew into something like that. My ported and muf modded 660 with a 42" bar could square it up and mill it down. I'm sure there are peeps on your side of the Mississippi that have bigger saws and bigger bars that could mill it in place.
As far as peavey vs cant vs timberjack -
I bought an NT timberjack with the big thick handle and used it on a 30' maple log. Need a board to put under the jack on soft ground, but worked fine for me to cut the wood into shorter lengths. I also bought a LogRite 60" Aluminum Handle Peavey, VERY heavy duty.
You can also put a logstand on it to make it into a timberjack. Universal Log Stand.
I like them both.
/ Anyone use a Cant #33
I also have the cheapo from northern tool that comes with a metal leg{Making it a timber jack ??} to lift smaller logs for cutting. I have moved locust{one of the heaviest woods} but I doubt highly it would lift a 20-30 foot sizable log onto the leg.
I have that one, and I can not really recommend it. It is all-steel, and
maybe 5-ft long, but I quickly bent it rolling a log up onto the stand. So
I removed the stand and now it is just a cant hook. I have a hard time
getting the hook to dig in well enough to roll the larger logs. It slips on
the bark. Perhaps better ones have sharper spiked hooks?
2015 Nissan Leaf Hatchback (A61574)
2015 Nissan Leaf...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
1996 EAST 96" X 48' FLATBED TRAILER (A64276)
1996 EAST 96" X...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2012 23ft Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61574)
2012 23ft...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
