Anyone put grease in Howse cutter gearbox
   / Anyone put grease in Howse cutter gearbox #21
We use grease in out howse bush hog. We use a tube of hi temp grease and 8 oz of 90 wt gear oil.
   / Anyone put grease in Howse cutter gearbox #22
Follow up post.
I brought the brush hog home last weekend and went to work on it tonight using advice from my farm neighbor. He said you need to whup on top of each side of the bar that the blades and pan are attached to. I almost gave up after putting a propane torch on it and hitting one side with a sledge and then the other. Wouldn't you know,,,,,,,,I couple of light taps before I was going to call it a night dropped the pan.
Bad news is the shaft is .010 out near the threads and .009 out about 3/4 of an inch away from the gearbox. :mad:
I was walking through the pasture Saturday and noticed the rock I had hit a year earlier. I need to get that thing loaded and hauled to the rock pile. :D
shaft wear will mean bearing play.. which is why the seal weeps.
Any chance of sleaving it?
soundguy
I went to AgMart where I bought the Howse and the owner seemed to think this gearbox was the replacement. It looked identical but I didn't have the old one with me. The castings and everything is identical. The red one has a Cheetah sticker on it and the black one has a Grizzly sticker on it. Here's the difference. The red cheetah (old) has a ratio of 1:1.93
The replacement has a ration of 1:1.47
Is it much of a difference to worry about? It's used on a 20HP Kioti.
The rust on the new one is from being stored outside as is typical with this store. Bigger pictures at this location
soundguy
Shaft is bent. This unit probably didn't have 5 hours on it from new.
   / Anyone put grease in Howse cutter gearbox #25
Dang.. bent.. that's more or less a death sentence unless you can find the saft.. or take lots of work at a blacksmith and machinist. IMHO.. not worth it.
1:1.93 at 540 rpm input means output shaft is spinning at 1042.2 rpm
1:1.47 at 540 rpm input means output shaft is spinning at 793.8 rpm
that's about a 24% reduction... you would need a pto rpm of 709 to achieve the same output shaft speed.
IMO.. I wouldn't run anything over 600 on a mower like that... that will yeild 882 output rpm on the new box... which is a 15.4% reduction.. and IMHO.. nothing to worry about on a rouch cut brush cutter.
just my opinions...
soundguy
Thanks for the feedback Soundguy.
   / Anyone put grease in Howse cutter gearbox #27
in my older Howse 6' finishing mower, I just put in 3 new bearings.. now when cutting I get a leak from the top fitting that you put grease in.
I put in new rubber ring tape but still getting a leak and it is TIGHT..
and where on this gear box is the over flow??? I only see where you put grease in??
I'm stumped..
   / Anyone put grease in Howse cutter gearbox #28
Not familiar with your mower, if you are leaking grease after you use it, you are probably over greasing it and the grease needs to expand when it heats up. My post from 2008 still applies, The old tired bush hug is STILL chopping along. even after I put a whuppin on her trying to open some heavy brushed trails this summer..... :thumbsup:
   / Anyone put grease in Howse cutter gearbox #29
I'm stumped..
the top is the fill.. it should be a vented cap.. if you overfill it it will leak. if you use the wrong oil and it foams it may leak out the cap... and SOME minor spalsh out a vent cap will still be normal anyway..
   / Anyone put grease in Howse cutter gearbox #30
I'm stumped..
SET OF CATERPILLAR SKID STEER PALLET FORKS MAST (A51244)
SET OF CATERPILLAR...
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
UNUSED CFG INDUSTRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
