Anyone made Grass Seeder
/ Anyone made Grass Seeder #1
Jbbies
Bronze Member
Colorado
Kubota B2620
Anyone on here make a grass seeder? I am thinking about it and figure it could be done a lot cheaper than buying one. Biggest thing would be coming up with the cultipacker reasonable.
B
/ Anyone made Grass Seeder #2
For what it is worth I use a an old John Deere, fertilizer spreader, (it looks like a drill box) (in the manual it had what was called grass seed cage) and since I could not find any new, I made my own and replaced the fertilizer agatator, (I think the fertilizer agitator would have worked OK, the bottom has slots that you open up more, on the JD spreader the cage is wheel driven direct, the cage is about 6" around and all it does is drag the seeds over the holes, (works well with the fluffy grass seeds),
http://www.tractorbynet.com/forums/projects/71609-lime-spreader-food-plots-4.html
in this post there is a picture of the seed atagator
very similar to a "Ezee Flow" spreader
similar to mine, (mine does not have the small seed boxes,)
I drag a single tree disk set very light behind it, (would like to find a old harrow the same width as the spreader),
here is a machine that looks interesting, (I would like the try the roller but not as aggressive), but most of my ground is blow sand,
The Imprinting Foundation
The Imprinting Foundation: Imprinting is Superior to Other Treatments for Ecological Restoration
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
2015 Jeep Cherokee 4X4 SUV (A59231)
2015 Jeep Cherokee...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A59228)
2025 GIYI GY-PG72C...
2012 Freightliner Cascadia (A61306)
2012 Freightliner...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
