Rear Finish Mower Anyone knows who makes this mower
   / Anyone knows who makes this mower #1
gooffer69
Kingston, NY
TZ18DA, TC45DA
Just picked it up today works nice and at $500 delivered I can't argue with its usefulness
   / Anyone knows who makes this mower #2
woods C80
   / Anyone knows who makes this mower #3
I don't know anything about the C80 part, but the drive shaft guard looks like the one on my Woods Cadet.
   / Anyone knows who makes this mower #5
May I ask how wide. If it's 6ft or smaller around here they robbed you badly. I know I know different parts of the country
   / Anyone knows who makes this mower #6
I don't recall ever seeing anything like that. It appears to be a rear discharge finish mower pull type??? I don't see any adjustment on the front hitch?? I understand the hyd cyl will lift the rear. So the front cannot be lifted?? Won't it scalp really bad??
If you look at the pic D7E posted you can clearly see the adjusters for front and rear cutting height.
   / Anyone knows who makes this mower #7
Can't the front be adjusted with the 3pt hitch height?
   / Anyone knows who makes this mower #8
The mower in the OP appears to be towed (via the drawbar).
Steve
   / Anyone knows who makes this mower #9
Not when it's hitched to the fixed drawbar.
If you did hitch to the 3pt you better be diligent or you'll have the 3pt drawbar into the PTO shaft!!!! :eek:
   / Anyone knows who makes this mower #10
Looking at the hitch, I would guess that it adjusts up and down manually so you set the front height by hand and then the back height with the cylinder. See the bar that goes down and in the middle of the front hitch?
Edit, here are the pictures I was looking at:
7: Woods C80 Pull Type Rotary Mower for Tractors : Lot 7
Aaron Z
2016 Bobcat E85 Midi Excavator (A55851)
2016 Bobcat E85...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
Metal Bull Smoker (A55853)
Metal Bull Smoker...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
