Anyone know who makes a Post Vise?
   / Anyone know who makes a Post Vise? #11
I've seen them now that I see some pictures. Have probably used one at some point. Not the name I would have called it though. Don't remember what we called them.
Suggestion to use a scissor jack screw seems worthy.
I'm glad we found some pictures. That type vise must have had a real name, but I don't know it either. Maybe that style never got to be real popular. I could see why, just about any other type of vise is better - but none cheaper. Especially for a big powerful vise. Big vises were/still are Expensive! But this one could be made cheaply with only a few iron parts. That would make it popular with pioneers.
Even today, everything except the screw, nut, and some way to mount the handle could be made out of scrap wood with a saw. Close tolerance fits not necessary. As you say, a scissor jack does have approximently the right pieces, maybe I'll build another one someday....Who knows, I may even mount it in the living room of our modern house just for nostalgia! The stairway has lots of posts......
In today's world, that Milwaukee Quick Release Bench Vise that Radio1 linked to in an earlier post looks to be more than twice as good a vise ..... for about 10X the price. Although any vise is better than none, truth is that any vise with more metal in it would work better than those old crude wood vises.
rScotty
   / Anyone know who makes a Post Vise? #13
The one my dad had was exactly like the one in rScotty's picture. Except - there was no "built in" lower leg adjustment on his. If you wanted the leg out - just put chunks of wood down there until it was right.
   / Anyone know who makes a Post Vise? #14
That can be done too. I have some old wood clamps with opposing wood screws. It would be a lot easier to make with a lathe, but a skilled woodworker could do it with a saw and chisel set.
No necessarily. Some things are better clamped in wood with soft(er) jaws that won't mar and apply as much pressure.
   / Anyone know who makes a Post Vise? #15
There are two types of post vice woodworkers and blacksmiths... Most popular reverence to "post vice" is the typed used in blacksmithing... If interested in blacksmith type check out info below...
Check out BLACKSMITHING suppliers like Centaur Forge or Pieh Tools.... They are still very popular in blacksmithing world.....
Vises-centaurforge.com
Got a used one for $20 had to do bit of restoration....
Blacksmith: Hammer Anvil & Forge - Photos | Facebook
Dale
   / Anyone know who makes a Post Vise? #16
Dad had one on the end of one of his benches, made from roughsawn 2x8 or so. Acme screw I suspect was rescued from a jack, there was a stack of fender washers and wood rings to support the screw against the wood. There was a 2nd smaller screw near the bottom that helped with adjusting the angle of the top jaws for larger pieces, I seem to recall chucking spacer blocks in on occasion. It was sufficient for cutting up wood with a handsaw or drilling with a single speed b&d drill or chiseling. It was lacking if you were trying to bend metal rods or pound over sheet metal or some such, but we also had a mechanics vise and a cast iron wood vise (one of those with the handle that ratchets and turns half way to lock)...eventually.
Dad's was painted, which seemed to help give it a hard surface and last longer. I suspect the wood was something like Hemlock, I don't think it was hardwood, which certainly would have been a step up. The nice thing about the jaws being made from wood is that it didn't matter if you cut too far, you wouldn't kill the edge on the handsaw. There were more than a few nicks in that top surface.
So depending on what you want to do, and the care and materials you chose to make it from, they can work very well or they can be pretty miserable.
If you want to buy one rather than scrounge and make one, a number of finer woodworking outlets sell both whole woodworking benches with that type of vise as well as a "vise screw kit" of screw, nut, and handle to make you own. Depending on how old school you want to go, you could also get a tap and die for making threads in hardwood and make a screw and nut out of something like maple.
As to the other type of leg vise, I found one at a fleamarket decades ago near closing time for a bargain, the seller didn't want to pack it up again.
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
Hydraulic rail grinder (A56435)
Hydraulic rail...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
White Metal Roof Panels (A55758)
White Metal Roof...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
406 (A52706)
406 (A52706)
