Anyone know the torque requirements for the glow plugs for kioti
   / Anyone know the torque requirements for the glow plugs for kioti #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
Ive traced a glow plug issue to a bad plug. I desided to replace all 4….. once one goes….
I ordered 4 new ones, but cant find the proper torque requirements, and/or weather i need to use a sealant.
Its for my 2010 DK45HSE
Thanks for any help. I cant find the info in the service manual.
   / Anyone know the torque requirements for the glow plugs for kioti #2
Thank you, i could not locate this in my service manual….and i looked pretty hard
Now that i saw your chart, i found it under the engine specs. Funny, i looked and looked and never saw that in the manual.
   / Anyone know the torque requirements for the glow plugs for kioti #5
Just amazes me how this site has so many knowledgeable folks and are willing to share it, and how to help me find it too. Never would a thunk to look there.
   / Anyone know the torque requirements for the glow plugs for kioti #6
Use
Use an Anti-Seize thread compound on the new Glow Plug threads. With the dis-similar of metals between the Head and the Glow Plug, we have seen several Glow Plugs that get seized in the Head. Spray the bottom of the existing Glow Plugs with Anti-Seize and let it sit for 15 minutes before attempting to remove the old Glow Plugs. A broken off Glow Plug is a complete bummer to deal with.
Hope this helps
   / Anyone know the torque requirements for the glow plugs for kioti #7
What were the symptoms you saw indicating a bad glow plug?
Use
Hope this helps
man, thanks for the heads up. would PB Blaster be a good spray to use?
ohmed them out. 1 is defiantly bad, another is marginal. other 2 ok.
but ill just replace all 4 while im at it. there 15 years old anyways.
checked relay and the display module is sending the signal for relay to close. the power from the 60 amp fuse is traveling thru to glow plugs. after that....not really coming up to temps.
started getting harder to start last winter. now its also having issues in summer. time to swap glow plugs.
this unit has ALWAYS fired up cleanly.
   / Anyone know the torque requirements for the glow plugs for kioti #10
So far I haven't seen anything like that. I will be on the watch for it though. Our kioti's are about the same age/model.
2002 Ingersoll Rand P185WIR Towable Air Compressor (A55851)
2002 Ingersoll...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
