Anyone know the spec on Bobcat hydraulic fluid ct445
   / Anyone know the spec on Bobcat hydraulic fluid ct445 #1
case310350
Need to add some hydraulic fluid to my system nobody Cat dealer near me so I was wondering if Tractor Supply would have an equivalent but I can't find the spec
   / Anyone know the spec on Bobcat hydraulic fluid ct445 #2
Tractor supply TRAVELLER hydraulic/trans oil is what I replaced in my tractor, when it was time.
This is what the guys here on this forum, said was to SPEC for my BCAT CT225.
HTH'S
Terry
   / Anyone know the spec on Bobcat hydraulic fluid ct445 #3
If this is the correct fluid, it is about half price from Bobcat fluid, I just purchased Thursday from Bobcat
Traveller Premium Universal Tractor Trans/Hydrauilic Fluid is a specially formulated, premium multigrade (SAE 10W-30) fluid blended with the highest quality lubricating oils and the most technologically advanced additive system.
Provides superior protection and performance for modern farm equipment
Employs a common sump to lubricate hydrostatic transmissions, differentials, wet brakes, hydraulics and final drives gears
Specification Description
Product Type: Hydraulic & Transmission Fluid
Brand: Traveller
ISO Viscosity Grade: 46
Pour Point: -44 deg. F
Shop By: Bulk Discount
Flash Point: 435 deg. F
Manufacturer Part Number 590901
   / Anyone know the spec on Bobcat hydraulic fluid ct445 #4
Brand: Traveller
Yes, that is it!
   / Anyone know the spec on Bobcat hydraulic fluid ct445 #5
I also use that in my CT235, seems fine to me, thinking I have changed it twice using the Traveler and she is still truckin. :thumbsup:
   / Anyone know the spec on Bobcat hydraulic fluid ct445 #6
2007 Capacity TJ6500T Trailer Jockey Truck (A55973)
2007 Capacity...
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
2020 DRAGON ESP...
Eaton Air Compressor (A56857)
Eaton Air...
