Anyone here install their own septic
   / Anyone here install their own septic #121
I think "3 hours" is WAY overly optimistic, for an installation.
Time to assemble materials at the job site, time to dig for tank and field lines, time to assemble the pieces, time to add stone, time to backfill/cover, etc.
With you having ZERO experience, and zero equipment, I would suggest getting a second estimate, and then go with the lower of the two.
There’s close to zero chance even an experienced 2 guy crew with a full size backhoe or trackhoe is going to put one in in 3 hours. Its probably 1.5 days work with 2 guys and a full-size backhoe. One guy, no experience and too small of a backhoe better plan for a week.
   / Anyone here install their own septic #122
Thereç—´ close to zero chance even an experienced 2 guy crew with a full size backhoe or trackhoe is going to put one in in 3 hours. Its probably 1.5 days work with 2 guys and a full-size backhoe. One guy, no experience and too small of a backhoe better plan for a week.
AT LEAST a week !
And.....FAILURE of county inspection to boot !!
   / Anyone here install their own septic #123
When I was thinking about installing mine 4 years ago, I estimated that it would save me about $1000. For that amount of money it was cheaper to hire someone who knew what they were doing.
   / Anyone here install their own septic #124
I put in 17 about 20 years ago. Regulations back then was not too bad here. Day one, dig hole for tank and level it. About 2 hours per tank. Day 2, have tank or tanks delivered and set in ground. Up to 2 at a time. 1 hour per tank. Dig and set field lines, about 4 hours per set. State inspection, 1/2 hour time to do it. But you have to wait on the inspector. Cover it all up, maybe an hour. Field lines were in the same area as the perk test. Perk tests had to be done by a civil engineer and approved by the state health department before start. They will tell you the size tank and the amount of field lines. I was only allowed to do them because they were on my property. Today, they only allow you to do one for your own house.
All approved installers must go to a class in the capital and pass a test and pay fee. All work by installers must still be inspected by the health department before it can be covered.
   / Anyone here install their own septic #125
Yeah, that's not going to work. But you didn't say how much slope. There's typically a minimum and maximum slope for sewer pipe. Last I checked it was 1/4" and 1/2", respectively, per foot!
I would put the tank up top near the house and step the drain field down the slope. By stepped, I mean drain field laterals about every 10 or so feet down the slope and perpendicular to the output pipe. You would need a collection box at each step so the liquid just doesn't run to the bottom.
The other way to do it is have a single distribution box at the top and then separate lines going down to each run (which goes across the slope). That way each run is fed equally.
Just redoing our septic field last year was two days for two guys who do this for a living. They had a mini x and all the toys to make it go well.
Aaron Z
   / Anyone here install their own septic #126
Aaron Z
That way would make a lot more sense to me but I’ve never seen them approve anything except the S shaped one with crossovers here. If anything clogs up or crushes any part of that system everything else downstream is useless. If the distribution box system suffers a failure almost if the system remains workable.
   / Anyone here install their own septic #127
My install took 3 men, including the one on hoe, about 7 hours. Set the tank, dug the main, and 5 80 ft laterals with infiltrators, and covered up. And I didn't see one of them break a sweat...
Easily done in 3 hrs or less with 2 guys, one guy to operate the mini excavator and the other guy to do the manual labor. I have talked with several installers and this time frame is the same across the board. Come back to bury after inspection.
   / Anyone here install their own septic #129
And ......your quote is $3,500 ???
no 2700 plus the permit cost of 600 which includes the soil test
Call Marion Pumpers or any one of the local septic pumpers/installers and tell them they arent charging enough or taking enough time to do the job if you wish, in the meantime Im gonna be having my system installed.
20702 (A51694)
20702 (A51694)
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2020 MACK P164T (A58214)
2020 MACK P164T...
2014 Chevrolet Impala Sedan (A56859)
2014 Chevrolet...
2009 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A57192)
2009 FORD F-350 XL...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
