anyone have this problem?
/ anyone have this problem? #1
deerefan
louisiana
1952 8N, 2005 JD 5103
This may actually be normal...I really do not know! I just bought a 5103 and a mid-duty 6ft Bushhog brand cutter. I let the tractor warm up at about 1200rpm for about 60 seconds then slowly head to whereever i may be working. I throttle the tractor up to about 1500rpm and engage the pto. I noticed when I do this it shakes the entire tractor harshly. It seems to subside once it is warm. Is this normal? Thanks /forums/images/graemlins/confused.gif
/ anyone have this problem? #2
You've got hinged blades right? It's probably just the blades swinging out and getting their balance.
they are hinged...never thought of that! Checked everything on the cutter and found nothing out of balance.
will give that a shot...thanks for all input!
/ anyone have this problem? #6
Something my dad taught me as a kid growing up on the farm was to engage the PTO at idle then throttle up. He said it would minimize wear and tear on the PTO clutch. Not sure if it applies to modern machines but I still do it. /forums/images/graemlins/smirk.gif
/ anyone have this problem? #7
"I noticed when I do this it shakes the entire tractor harshly. It seems to subside once it is warm. Is this normal?"
As Woody mentioned, getting those big heavy cutter blades extended and rotating does result in some vibration.
I normally engage the PTO at about 1000-1200 RPM (keeping my foot on the throttle in case the tractor starts to stall) and leave it at that RPM for 8-10 seconds. By that time, the blades will be extended and rotating.
Then increase the RPM to PTO speed smoothly.
As mentioned, I have a foot throttle to "blip" the RPM (as well as a throttle lever). If your tractor doesn't have a foot throttle, just keep your hand on the throttle you have. If the tractor starts to stall, just increase RPM slightly.
You'll still have vibration. Untill those blades are extended, there will be an unbalanced condition. Keeping the RPM low during engagement just reduces the severity of the vibration.
/ anyone have this problem? #8
I have an JD LX4 brush mower and found that it was vibrating a lot more than usual this past weekend. I noticed the deck was obviously off level and, after adjusting things, the vibration settled down.
But.. later in the day I hit a rock /forums/images/graemlins/blush.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif and things started shaking a bit and then 5 minutes later they settled down. When I checked underneath, I found one blade would pivot (not easily) at the half-way bolt but the other wouldn't. I just assumed they should be fixed and the movable one got knocked loose by the rock -- but maybe that's the way they should be.
I suspect the manual would tell me but I don't have it in the same state at the moment so I appreciate your thoughts.
Thanks,
Rod
/ anyone have this problem? #9
They should BOTH pivot. They might still be a bit stiff if the mower is relatively new. Those blades are designed to move when they hit something solid. Centrifigal force keeps them extended when they are in "normal use".
The blade's movement should free up with some use. If not, then look to see what has the "stuck".
/ anyone have this problem? #10
I am far from an expert or have not had as much experience as many folks on this forum however regardless of the vibration etc. I would suggest getting in the habit of what Woody71 indicated. Engage the PTO at low / idle RPM and then increase from there. This is the process I use and in my view is much better than engaging the PTO at an increased RPM.
Mark
/ anyone have this problem? #11
I know some about getting a brush hog going. I have found that it is good to be stopped and ingaged the PTO. I also have put a pto clutch on to help the shaft to spin freely even if I have stopped the PTO to turn around. But I do notice some movement when it gets going. I prefer to have some motion from it so I can tell that it is working.
/ anyone have this problem? #12
It is also good to check your Zerks and to repack the bearings.
/ anyone have this problem? #13
One day I lost my dog and could not find her. The kids started to cry and I was thinking that she must be hurt. She is an old fat black lab. But she can catch rabbits better then any other dog. And she can eat a 5 pound rabbit in one bite. I left her by my brush hog looking for rabbits. So I lucked everywhere for her. I asked my neighboor about where she was and I drove around. I found her stuck under the brush hog. I was laughing so hard I could not get my tractor started to lift up the hog. I thing she is scared to go near it now. /forums/images/graemlins/grin.gif
2019 WESTERN GLOBAL DOUBLE WALLED FUEL TANK (A64279)
2019 WESTERN...
2018 Ford F-350 Crew Cab Landscape Dump Truck (A61573)
2018 Ford F-350...
2022 Weber CR 5-II HD Reversible Plate Compactor (A61572)
2022 Weber CR 5-II...
2013 John Deere 7200 R Tractor (A66285)
2013 John Deere...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
Deutz D3006 Tractor (A62613)
Deutz D3006...
