Anyone have pictures of Quck Attach Handle Mods
   / Anyone have pictures of Quck Attach Handle Mods #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I am starting to collect parts for this summers upgrades / repairs to the PT. I am thinking about following JJ's advice and buying this handle
Surplus Center Item Detail
And the 50" cable and placing this on the left side of the wheel.
My concern is connecting this cable to the hydraulic control and wondering if anyone has pix of how that short little handle attaches and any other ideas on how to get it to work.
I searched the sight and it looked like a bunch of pictures were missing (bummer).
Carl
   / Anyone have pictures of Quck Attach Handle Mods #2
You can find a link to the picture of the mod I did on my PT422 in my signature. If I had to do it over again, I would make it about 2 inches longer/taller.
Let us know how yours goes!
KMA.. I saw those pix. But I did not see how the whole thing fits into the actual valve actuator.
I am 1000 miles away from my tractor so I am doing this through the kindness of others in terms of pictures and ideas.
But I do dig your system, I thought about it as a great solution but realized it would be nice to 2 hand the backhoe and that could only happen if the QA lever was on the left side...
   / Anyone have pictures of Quck Attach Handle Mods #4
Unfortunately, I'm at work and don't have access to a good picture. :(
On the 422, there was a small lever that actuated the valve. When my modification extended it out and up, I just matched the stock shape and hole pattern on the valve end of the new longer lever. It's hard to describe, but IIRC there were two holes on the lever where it mated with the valve. One hole was used to fix the lever at a pivot point, and the other had a pin through it connecting it to the valve piston. When you pushed down, the piston moved up and vice versa.
I don't know much about the handle and cable system you are using, but I'd imagine you could mount the cable above the valve, and attach it to a shortened version of the existing lever. When the cable pushes outward, the lever is pushed down, and the valve piston moves up, etc... If you didn't want to cut the stock lever, you could make a new one out of a short piece of 1/2" round stock, grinding the section with the holes flat so it can fit into the valve system. Or find some stock that was a better fit from the start.
Hope that was somewhat helpful, and made a bit of sense. Again, I'm guessing at what you are trying to do and I'm not familiar with the 1850 layout. On the 422, the two handed operation wouldn't be as beneficial since you need to articulate the tractor to dump the mini hoe.
Best of luck!
   / Anyone have pictures of Quck Attach Handle Mods #6
Having the quick attach handle on the left side of the console would be ideal to me but when I looked at what it would take to relocate I opted to do this instead.
   / Anyone have pictures of Quck Attach Handle Mods #7
Very nice! Did you make that, or purchase the handle as a direct fit?
Thanks.
Swampman.
That falls under the make a few of those and sell them category
Very nicely done...
   / Anyone have pictures of Quck Attach Handle Mods #9
Great job!
I am continually impressed by the talent and creativity shown by PT users here at TBN.
All the best,
Peter
   / Anyone have pictures of Quck Attach Handle Mods #10
Thanks.
I made it. It was raining here today so I went into the shop and removed all the metal that did not look like a handle extension.
2018 Gehl R105 (A50123)
2018 Gehl R105...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A53426)
2019 HINO 195 16...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
UNUSED RAYTREE RMSG-29 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
