Anyone Have One Of These DR Trimmer's?
   / Anyone Have One Of These DR Trimmer's? #31
I like a perfect job when trimming. When my lady friend does it, she just does such a hatchet job! You need to observe what's happening and give a little more here and not so much there. I can't see a pulled one, giving nice results. I guess it all depends how fussy you are.
   / Anyone Have One Of These DR Trimmer's? #32
Found a never used engine powered one on CL no far away, called the guy, said it was given to him, he will take $600 for it, I said I'll be there before noon tomorrow..
7.25hp, I'll pull it with my ATV and give it a try..
Nice. Some things to check before you start:
1. Make sure the spring that keeps it from rotating back is just tight enough to keep it in the normal position
2. New string (preferably soaked in water from what I understand, that makes it more tolerant of abuse)
3. Make sure the swivel tire is fully inflated
4. Hit the post in the "impact zone", too far in and it will suck the whole mower in, too far out and it will miss part of the fence line
Aaron Z
Aaron Z
Perfect and thank you for the pointers.. Saves me from learning the hard way..
   / Anyone Have One Of These DR Trimmer's? #34
New small engines sometimes go through oil the first time you have them out.....keep checking the oil often.
Okay, he did say he never started it.. I'll bring oil. I run synthetic in everything so I hope it's empty actually..
   / Anyone Have One Of These DR Trimmer's? #36
I am going to have a ton of fence posts to cut around and this thing looks promising. Does anyone have one or have any input on them?
3-Point Hitch Trimmer Mower: String Trimmer and Fence Mower | DR Power Equipment
I bought the one from Titan, very similar, not impressed with it. I have 2400 feet of wooden fence to trim and the bottom board varies slightly in ground clearance. If I had a smaller tractor it might work better. Too bad you are so far away, I would let you use it.
   / Anyone Have One Of These DR Trimmer's? #37
I would doubt they sell DR returned stuff. My friend gets them for nothing. He has repaired at least one for his own use.
They have a 6 month return policy, which is most likely where the used items are coming from.
I will have a board on the top and one in middle, nothing down low, I'm thinking the small ATV might work okay, will see, thank you for the offer but it would cost me more than the mower is worth in fuel for me to borrow it from you.. :laughing:
Picked it up this AM, no oil or fuel ever in it, brought some NON ethanol and synthetic oil with me, cranked it four times and off she went. I saved at least $400, I'll let you guys know how it works, thanks to all the input guys..
   / Anyone Have One Of These DR Trimmer's? #40
I bought a DR mower like you describe. What a POS! Both tires went flat as the tall grass wound around the axle. I replaced both tires with solid tires so this couldn’t happen again (a $125+ upgrade). The drive belt has broken twice...the first time an hour into my first use.
On a positive note..the B&S engine has been reliable. i would only give this machine 2/5 stars. Be sure to order an extra belt and be prepared to upgrade tires. Good Luck!
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
Electric Horseless Carriage (A57453)
Electric Horseless...
Armstrong 64-405A Torque Wrench (A59076)
Armstrong 64-405A...
jet ski trailer (A56859)
jet ski trailer...
