Anyone Have A Mile Marker Hydraulic Winch?
   / Anyone Have A Mile Marker Hydraulic Winch? #11
I believe you only need to use a pressure regulator to control the max pressure and if you run the tractor at idle, you should be good to go.
Good points about running at idle. I may be seeing a problem that doesn't exist.
I am also planning to install a one way valve, just in case some idiot (such as myself :p) operates the remote valve in the wrong direction by accident. Right now, I have no idea what would happen if that winch was back fed. Anyone know?
   / Anyone Have A Mile Marker Hydraulic Winch? #13
radman1,
Thanks for that information.
I'll get one if the winch doesn't already have one on it...anybody know if it does?
   / Anyone Have A Mile Marker Hydraulic Winch? #14
I think it would just run backwards. I think the only difference between 3RRL's and my own is the solenoid setup. Mine runs backwards to power out and I can't imagine they're using two different motors...
   / Anyone Have A Mile Marker Hydraulic Winch? #15
In my Parker Torqmotor catalog, the lowest pressure rating I see is 300 bars, or, 4350 p.s.i.
Thanks.
   / Anyone Have A Mile Marker Hydraulic Winch? #17
I have a mile marker 12,000lb winch I bought last yr to run on my Deere5400. Tractor pressure is 2950psi. I simply went to Surplus Center and bought a 2 way pressure reducer adjustable. haven't used it yet. I called MM and they said absolutely no more than the 1500psi. The valve was cheap. I'm planning on plumbing it to run off the joystick.
2014 TROXELL 130BBL VACUUM TRAILER (A52472)
2014 TROXELL...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
8X20' SHIPPING CONTAINER (A52472)
8X20' SHIPPING...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
