Anyone have a MechMaxx 3-pt stump grinder?
   / Anyone have a MechMaxx 3-pt stump grinder? #91
Anybody use one on a manual transmission tractor? I know that hydrostatic is ideal, but I don't have one.
I 100% would say you hate it, I make constant adjustments in speed using it. your going to burn up a clutch slipping it enough to be usable
   / Anyone have a MechMaxx 3-pt stump grinder? #92
I run mine (though it's different than yours), I have the model with hydraulic swing and depth on my gear drive Kubota but I use the one with the optional creep gears and and I run it in low creep... and I have no clutch as mine is hydraulic shuttle, ie; wet pack.
   / Anyone have a MechMaxx 3-pt stump grinder? #93
Agreed - it woul be VERY difficult to use with a no hydro because that controls your cut
   / Anyone have a MechMaxx 3-pt stump grinder? #94
I agree as well and why I use the Kubota with the creep gears when grinding stumps. No dry clutch is also a benefit.
   / Anyone have a MechMaxx 3-pt stump grinder? #95
My stump grinder works perfectly on my AGCO with "creep" transmission, no clutch slipping or any other problems at all.
SR
   / Anyone have a MechMaxx 3-pt stump grinder? #96
My 790 has pretty deep low range gears. I think that I could manage it.
   / Anyone have a MechMaxx 3-pt stump grinder? #97
Never said it could not be done, but a lot more difficult. Without a hydro swing, you are stuck controlling the cut with the transmission. I ground a 45" oak out today and had to go up and over it at odd angles and without a hydro, it would be a real challenge. Some spots it would be taking a nice bite, but then as I rolled over it, the stump grinder would change heights due to the position of the wheels, so I would have to slow to a stop and readjust. That would be tough with a gear drive without having to clutch often.
   / Anyone have a MechMaxx 3-pt stump grinder? #98
SR
Same deal with the Kubota with creep gears. I believe at rated rpm, my ground speed in low creep is like 1/10th mph, maybe even less. Have a speed chart on the side window so I could look, but never do. Clutch issue is nonexistent as it has no clutch anyway. Multiplate wet clutch, only way to fly in my view.
   / Anyone have a MechMaxx 3-pt stump grinder? #99
I guess if you have never ran a grinder with "creep" trans you really don't know for sure. I have BOTH types of trans, and I much prefer to grind stumps with my above AGCO with creep.
I've ground some huge oaks, but I've never found not having the whinner trans to be a "real challenge".
SR
   / Anyone have a MechMaxx 3-pt stump grinder? #100
I honestly was referring to the normal Kubota's, Deers, and similar-style compact tractors and transmissions.
Golf cart (A56859)
Golf cart (A56859)
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
405 (A52706)
405 (A52706)
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
204158 (A57193)
204158 (A57193)
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
