Anyone have a MechMaxx 3-pt stump grinder?
   / Anyone have a MechMaxx 3-pt stump grinder? #91
Anybody use one on a manual transmission tractor? I know that hydrostatic is ideal, but I don't have one.
I 100% would say you hate it, I make constant adjustments in speed using it. your going to burn up a clutch slipping it enough to be usable
   / Anyone have a MechMaxx 3-pt stump grinder? #92
I run mine (though it's different than yours), I have the model with hydraulic swing and depth on my gear drive Kubota but I use the one with the optional creep gears and and I run it in low creep... and I have no clutch as mine is hydraulic shuttle, ie; wet pack.
   / Anyone have a MechMaxx 3-pt stump grinder? #93
Agreed - it woul be VERY difficult to use with a no hydro because that controls your cut
   / Anyone have a MechMaxx 3-pt stump grinder? #94
I agree as well and why I use the Kubota with the creep gears when grinding stumps. No dry clutch is also a benefit.
   / Anyone have a MechMaxx 3-pt stump grinder? #95
My stump grinder works perfectly on my AGCO with "creep" transmission, no clutch slipping or any other problems at all.
SR
   / Anyone have a MechMaxx 3-pt stump grinder? #96
My 790 has pretty deep low range gears. I think that I could manage it.
   / Anyone have a MechMaxx 3-pt stump grinder? #97
Never said it could not be done, but a lot more difficult. Without a hydro swing, you are stuck controlling the cut with the transmission. I ground a 45" oak out today and had to go up and over it at odd angles and without a hydro, it would be a real challenge. Some spots it would be taking a nice bite, but then as I rolled over it, the stump grinder would change heights due to the position of the wheels, so I would have to slow to a stop and readjust. That would be tough with a gear drive without having to clutch often.
   / Anyone have a MechMaxx 3-pt stump grinder? #98
SR
Same deal with the Kubota with creep gears. I believe at rated rpm, my ground speed in low creep is like 1/10th mph, maybe even less. Have a speed chart on the side window so I could look, but never do. Clutch issue is nonexistent as it has no clutch anyway. Multiplate wet clutch, only way to fly in my view.
   / Anyone have a MechMaxx 3-pt stump grinder? #99
I guess if you have never ran a grinder with "creep" trans you really don't know for sure. I have BOTH types of trans, and I much prefer to grind stumps with my above AGCO with creep.
I've ground some huge oaks, but I've never found not having the whinner trans to be a "real challenge".
SR
   / Anyone have a MechMaxx 3-pt stump grinder? #100
I honestly was referring to the normal Kubota's, Deers, and similar-style compact tractors and transmissions.
8 sets of Jumper Cables (New/Unused) (A59225)
8 sets of Jumper...
METRIC DUAL CUT TAP & DIE SET (A58374)
METRIC DUAL CUT...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A56435)
2017 Cadillac...
2015 Chevrolet Express Box Truck, VIN # 1GB3G3CG3F1110762 (A57453)
2015 Chevrolet...
JOHN DEERE 9410 MAXIMIZER COMBINE (A52708)
JOHN DEERE 9410...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
