Anyone have a JD 4600 / 4700 with creeper gear?
   / Anyone have a JD 4600 / 4700 with creeper gear? #1
PsRumors
Cartersville (NW) Georgia
Kubota L45
If so, do you mind posting a picture of where the shift linkage attaches to the trans?
   / Anyone have a JD 4600 / 4700 with creeper gear? #2
Puzzled.. Which transmission do you have?
I have the 12x12 powrReverser trans. It was offered with an optional creeper gear. I am wondering where on the trans the creeper gear linkage attached
   / Anyone have a JD 4600 / 4700 with creeper gear? #4
Here is what JD parts catalog shows, if it helps
   / Anyone have a JD 4600 / 4700 with creeper gear? #5
I could find the two different transmissions for the PRT and will post them. Maybe you can figure the differences that might help locate the linkage.
I will search the tech manual some more, but have not found anything yet. Add that Zebrafive 's post may be just what you need...
Thanks guys, i've already looked at the parts diagrams but for what I need, i'd like to see real world photos...of course what are the chances of finding one of these with a creeper?
   / Anyone have a JD 4600 / 4700 with creeper gear? #7
How about some pics of what you have on your end..? Maybe they could help trigger some advice that you could use.
I have a 4700 with the PowrReverser trans. I don't have a creeper gear so I don't know how much pictures of my trans will help someone else that has the creeper show pictures of the creeper linkage.
   / Anyone have a JD 4600 / 4700 with creeper gear? #9
Are you thinking of adding the creeper? Or thinking the gears are there, but just the linkage needs to be added to shift the gear that adds the creeper?
In the first parts diagram Zebrafive posted, part number 5 ("arm"), I am wanting to know where that exits the case. I can't follow the diagrams well enough to determine. Initially I was thinking about adding the creeper gear if I could but I have an extra arm sticking out the side of the case.
I can't imagine JD installed the gears in all the transmissions and all that is needed is linkage but the tractor is 20 years old, who knows what has been done to it over the years
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2 Axle Trailer (TITLE) (A50774)
2 Axle Trailer...
2016 Ford F-450 Ext. Cab Knapheide Stakebody Flatbed Truck (A50323)
2016 Ford F-450...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
