Tiller Anyone have a Cat 0 3 Pt tiller?
   / Anyone have a Cat 0 3 Pt tiller? #1
dbritton
Aumsville Oregon
Yanmar 2T75U-N 14HP Diesel
I have a Yanmar garden tractor it uses catagory 0 attachments with it's 2000 rpm PTO. I am looking for any attachments or advice on cat 0 attachments. Are the trouble? Are the hard to find?
Expensive parts? ect.
Thanks Dan B
   / Anyone have a Cat 0 3 Pt tiller? #3
I use a Cat. "0" tiller on the back of my J.D. 445 and it works fine. As a matter of fact, this tiller is set up with "duplex" mounts. I ca use it on CaT. "0" OR Cat. "1" 3Pts. I often attach it to my 4010 for use. I just had to make a different shaft end for the tractor side. Are you sure that the rear PTO is 2000 rpm ? It shouldn't be.
   / Anyone have a Cat 0 3 Pt tiller? #5
I believe the standard PTO speed for Cat 0 was 2000 rpm once upon a time. 70's and 80's garden tractors often had either stock or as an option a rear PTO - and 2000 rpm seemed to the most common speed provided, although there where other speeds around. The higher speed allows a given PTO hp to be passed along with a lot less torque load on those lightweight PTO driveshaft components than 540 rpm would have. Doesn't seem to be too much out there today built for that speed.
   / Anyone have a Cat 0 3 Pt tiller? #6
Simplicity and other large garden tractors have Cat 0 tillers. Check their specs to see if that would work.
   / Anyone have a Cat 0 3 Pt tiller? #7
Be careful. I believe some, if not all, of the older CAT 0 PTOs turned the opposite direction of the standard 540 PTOs and the newer JD CAT 0 PTOs (like the 445).
   / Anyone have a Cat 0 3 Pt tiller? #8
Check befco. I bought a befco Cat 1 540 RPM tiller recently and I believe they have Cat 0 2000 RPM tillers as well.
   / Anyone have a Cat 0 3 Pt tiller? #9
I have a excellant working 2000rpm tiller cat 0 for your tractor 850 .00 in north east pa
484-619-4125
   / Anyone have a Cat 0 3 Pt tiller? #10
484-619-4125
This thread is approx. 7 years old. I think the O.P. probably has his tiller by now.
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
GEHL RT175 GEN 3 SKID STEER (A52707)
GEHL RT175 GEN 3...
E-Z-Go ST350 Utility Cart (A55851)
E-Z-Go ST350...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2006 TK Equipment CM9 Towable Concrete Mixer (A55851)
2006 TK Equipment...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
