Tiller Anyone have a Cat 0 3 Pt tiller?
   / Anyone have a Cat 0 3 Pt tiller? #1
dbritton
Aumsville Oregon
Yanmar 2T75U-N 14HP Diesel
I have a Yanmar garden tractor it uses catagory 0 attachments with it's 2000 rpm PTO. I am looking for any attachments or advice on cat 0 attachments. Are the trouble? Are the hard to find?
Expensive parts? ect.
Thanks Dan B
   / Anyone have a Cat 0 3 Pt tiller? #3
I use a Cat. "0" tiller on the back of my J.D. 445 and it works fine. As a matter of fact, this tiller is set up with "duplex" mounts. I ca use it on CaT. "0" OR Cat. "1" 3Pts. I often attach it to my 4010 for use. I just had to make a different shaft end for the tractor side. Are you sure that the rear PTO is 2000 rpm ? It shouldn't be.
   / Anyone have a Cat 0 3 Pt tiller? #5
I believe the standard PTO speed for Cat 0 was 2000 rpm once upon a time. 70's and 80's garden tractors often had either stock or as an option a rear PTO - and 2000 rpm seemed to the most common speed provided, although there where other speeds around. The higher speed allows a given PTO hp to be passed along with a lot less torque load on those lightweight PTO driveshaft components than 540 rpm would have. Doesn't seem to be too much out there today built for that speed.
   / Anyone have a Cat 0 3 Pt tiller? #6
Simplicity and other large garden tractors have Cat 0 tillers. Check their specs to see if that would work.
   / Anyone have a Cat 0 3 Pt tiller? #7
Be careful. I believe some, if not all, of the older CAT 0 PTOs turned the opposite direction of the standard 540 PTOs and the newer JD CAT 0 PTOs (like the 445).
   / Anyone have a Cat 0 3 Pt tiller? #8
Check befco. I bought a befco Cat 1 540 RPM tiller recently and I believe they have Cat 0 2000 RPM tillers as well.
   / Anyone have a Cat 0 3 Pt tiller? #9
I have a excellant working 2000rpm tiller cat 0 for your tractor 850 .00 in north east pa
484-619-4125
   / Anyone have a Cat 0 3 Pt tiller? #10
484-619-4125
This thread is approx. 7 years old. I think the O.P. probably has his tiller by now.
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2018 HAMM HD 10C SMOOTH DBL DRUM ROLLER (A52707)
2018 HAMM HD 10C...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2013 Ford F450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F450 4x4...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
