Anyone have a Bad Boy Rogue?
/ Anyone have a Bad Boy Rogue? #1
BigBlue1
Elite Member
Middle MN
JD: 2520 & x758
I have a 2021 Bad Boy Rogue. I just performed the 50 hour initial hydrostatic system fluid & filter change. Followed the instructions in the service manual... Removed the filters and breather cover to allow to drain fully, then install new filters and added fluid. Also did the air purge process.
Each side only took 1.5 quarts of 20W50 oil, though the service manual says "takes approx 2.5 quarts per side". The reservoirs are full and the oil level is to the top fitting of the sight tube on the reservoir. In total I added 3 quarts.
Just curious if anyone else has a Rogue how much oil your hydro system required?
