ANYONE gotta YM1700????
   / ANYONE gotta YM1700???? #1
NCGMAN
NORTH CAROLINA
YANMAR
any of you ever owned or knew someone who had a YM 1700>> would like to know how they operate,, it's a 4x2. 20hp. about what year were they made??? can't find any info on this tractor.. is it to old and are parts readily available (hope i don't need any)... BUT!!!! THE price is right $1900.00
i am still looking for a tractor. want a 4x4 but $$$$ is getting tight and may have to settle for what i can find.... :eek:
   / ANYONE gotta YM1700???? #2
Don't know anything about that mod. If you want a 4x4 and don't get it , you may regret it later.Sometimes, it's better to wait & Save a little more $ and get what you want
   / ANYONE gotta YM1700???? #3
Bought my YM1700 about 8 months ago. I still don't know the year model, but been very pleased for what I got it for. I have a John Deere 4400 with loader and it seemed everytime I turned around I had to take an implement off to use the Woods mower or bushhog. I wanted a cheap dependable diesel and I found the Yanmar. I would not depend on it to do heavy work but it handles the 4' Woods mower and the 5' bushhog perfectly. I had to add about 80 lbs. of weight on the front to stop the wheelies.
I have not added the water pump option as of yet. I am waiting to see how it does this summer
I was fortunate as the tractor only had 680 hrs. when I bought it. I highly recommend the YM1700 if you need a light duty tractor.
My wife likes the Yanmar because with the 2 cylinder knock she knows where I am in the fields if she needs me for something.
   / ANYONE gotta YM1700???? #4
Doesn't that little tractor have a hard time with a 5 ft. cutter ? I have a 3110 & a 5 footer is all I run. I could probably run a 6 footer but, I think that would be a little much for mine
   / ANYONE gotta YM1700???? #5
There are quite a few YM1700 and near-identical tractor owners on here. A slightly modified version of the same tractor was sold in the US when Yanmar had dealers here, it was designated YM195.
There is also a near-twin with larger-bore cylinder sleeves, YM2000, and the YM2000's US brother was YM240. That's what I have. Search here for all those models and you will find a lot of posts.
Also take a look at the US sales brochures referenced from my sig, below.
For all four of these there was an 'early' and 'late' series. Early had headlights alongside the grille, for Late the headlights are in the front/top of the grille. The only difference is the sheet metal and in a few cases you need to specify early or late to get the right replacement part.
I've read YM1700/YM2000 was sold in Japan about 77-79, and that they went from green paint to red for the Late series.
The US YM195/YM240 were all pale green, early and late, and were sold until about 1982. My parts book says it applies to years 1975 and up so I wonder if these, or the Japanese versions, were sold earlier than 75.
I've read that these are about the best supported models, and my experience over four years is that everything is available easily. I get stuff from hoyetractor.com and there are other good suppliers also.
If the size of the tractor is suitable and its condition checks out ok, you can't go wrong.
4x4 on a tractor this old could get expensive to fix, and of course raises the price. I might buy newer if I needed 4x4 and intended to use it hard. I have 2wd and consider it sufficient for my use, no problems.
   / ANYONE gotta YM1700???? #6
I have a YM 1700 I mow with . And it will pull a 5 foot light weight bush-hog .What I like about the YM 1700 you put 5 gal in it . And mow for two days all day.
   / ANYONE gotta YM1700???? #7
Gizmo36 said:
I have a YM 1700 I mow with . And it will pull a 5 foot light weight bush-hog .What I like about the YM 1700 you put 5 gal in it. And mow for two days all day.
So true! I read somewhere that these are right up there with the most fuel efficient tractors ever made.
(Maybe the Nebraska Tests?)
   / ANYONE gotta YM1700???? #8
I did put a water pump on mine.
I am going to try and post a picture of the YM1700 for $1995.00. has a little rust on front grill. The owner of company (Arch's Tractors on the Creek) in Fairview, N.C. says it is a trade in for a bigger tractor. It is one of the remanufactured ones he sold earlier. Says everything works good. Will stand behind it,, I wonder if he means while it is running there on the lot???? so here goes with the picture....
I DONE IT!!!!! DANG!!!!
   / ANYONE gotta YM1700???? #10
Yeah, the one I had would almost get me in trouble. It used so little diesel you forget to check it. Almost ran out a couple of times.
I also put a water pump on mine.
They are amazing little tractors.
20 ft. Shipping Container (A53117)
20 ft. Shipping...
Tool Box with miscellaneous items (A53117)
Tool Box with...
11 SERVICE BODY BED (A53843)
11 SERVICE BODY...
2013 CHEVROLET TAHOE (A53843)
2013 CHEVROLET...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
