Anyone finish mow with a LS xj2025h?
   / Anyone finish mow with a LS xj2025h? #1
dustin3207
St.stephen MN
Yanmar YM1602D
I'm selling my Yanmar and Dixon ram ZTR and am looking for a replacement for the two. Was wondering if anyone has had scalping problems with the 60" deck?
I do want an all in one machine but don't want to pay the green price for less tractor.
   / Anyone finish mow with a LS xj2025h? #2
I highly recommend not getting a MMM. We really need to know your intended use and property conditions to be very helpful.
My house is on 1.25 acres and has about 15 trees that I mow around. New Hunting land is 20 acres with 2 food plots that are about 2 acres combined and some brush mowing. I also have 6 tilling accounts that equal about 2 acres.
Can you emphasize a little more on the recommendation of the MMM.
   / Anyone finish mow with a LS xj2025h? #4
Before we got our LS XR4046HC we had a Kubota B2710 with a 72" mid-mount mower. It cut very well and I had no issues with scalping.
Bought an 84" LS Rear Finish Mower for the XR and use it to cut open areas in our 9+ acre yard around house at the ranch.
   / Anyone finish mow with a LS xj2025h? #5
I second not getting the MMM. It limits your ability w/the tractor a lot. I have a LS J2023 w/ a 60" Rear finish mower cutting the same amount as you & love it. You will be very surprised at how well a Finish mower will work.
   / Anyone finish mow with a LS xj2025h? #6
I have a Land Pride 60 inch rear finish mower I pull with a G 3033, no issues with scalping, very nice cut
Is there a difference between a 3 point finish mower and a MMM? Besides the difference in the way it's mounted.
   / Anyone finish mow with a LS xj2025h? #8
Both are just large lawn mowers designed to have sharp blades that ....... cut the grass.
IMHO a MMM is more maneuverable since everything is under the tractor. I think I had the MMM off of my Kubota once or twice. It was designed to raise and pin in raised position. It had 72" cutting width so I could cover a lot of lawn in a short time.
My LS 84" RFM results on a very nice cut as well.
   / Anyone finish mow with a LS xj2025h? #9
Yes, MMM and RFM cut differently and disperse clippings differently. A RFM follows ground contours better, but does not leave a manicured cut like the MMM side discharge. A MMM cuts grass like a zero turn, it will stripe, and it does leave a professional level cut...but it does not follow ground contours.
If you dont want a perfect yard, RFM is fine. If you want zero turn cut quality, a MMM is the ONLY way to go.
   / Anyone finish mow with a LS xj2025h? #10
I have a 72" side discharge RFM a 84" rear discharge RFM and a zero turn.
The RFM rear discharge disperses clipping differently (out the back), but it has a nice cut.
The 72" side discharge RFM disperses clippings about the same as my zero turn 72" side discharge. I can't tell any difference in cut quality between the 2.
Don't do striping, so I don't know about any differences there.
2016 Chevrolet Tahoe 4x4 SUV (A50324)
2016 Chevrolet...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
2012 GMC SAVANA BOX TRUCK (A51243)
2012 GMC SAVANA...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2016 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2016 MACK ELITE...
