Anyone finish mow with a LS xj2025h?
   / Anyone finish mow with a LS xj2025h? #1
dustin3207
St.stephen MN
Yanmar YM1602D
I'm selling my Yanmar and Dixon ram ZTR and am looking for a replacement for the two. Was wondering if anyone has had scalping problems with the 60" deck?
I do want an all in one machine but don't want to pay the green price for less tractor.
   / Anyone finish mow with a LS xj2025h? #2
I highly recommend not getting a MMM. We really need to know your intended use and property conditions to be very helpful.
My house is on 1.25 acres and has about 15 trees that I mow around. New Hunting land is 20 acres with 2 food plots that are about 2 acres combined and some brush mowing. I also have 6 tilling accounts that equal about 2 acres.
Can you emphasize a little more on the recommendation of the MMM.
   / Anyone finish mow with a LS xj2025h? #4
Before we got our LS XR4046HC we had a Kubota B2710 with a 72" mid-mount mower. It cut very well and I had no issues with scalping.
Bought an 84" LS Rear Finish Mower for the XR and use it to cut open areas in our 9+ acre yard around house at the ranch.
   / Anyone finish mow with a LS xj2025h? #5
I second not getting the MMM. It limits your ability w/the tractor a lot. I have a LS J2023 w/ a 60" Rear finish mower cutting the same amount as you & love it. You will be very surprised at how well a Finish mower will work.
   / Anyone finish mow with a LS xj2025h? #6
I have a Land Pride 60 inch rear finish mower I pull with a G 3033, no issues with scalping, very nice cut
Is there a difference between a 3 point finish mower and a MMM? Besides the difference in the way it's mounted.
   / Anyone finish mow with a LS xj2025h? #8
Both are just large lawn mowers designed to have sharp blades that ....... cut the grass.
IMHO a MMM is more maneuverable since everything is under the tractor. I think I had the MMM off of my Kubota once or twice. It was designed to raise and pin in raised position. It had 72" cutting width so I could cover a lot of lawn in a short time.
My LS 84" RFM results on a very nice cut as well.
   / Anyone finish mow with a LS xj2025h? #9
Yes, MMM and RFM cut differently and disperse clippings differently. A RFM follows ground contours better, but does not leave a manicured cut like the MMM side discharge. A MMM cuts grass like a zero turn, it will stripe, and it does leave a professional level cut...but it does not follow ground contours.
If you dont want a perfect yard, RFM is fine. If you want zero turn cut quality, a MMM is the ONLY way to go.
   / Anyone finish mow with a LS xj2025h? #10
I have a 72" side discharge RFM a 84" rear discharge RFM and a zero turn.
The RFM rear discharge disperses clipping differently (out the back), but it has a nice cut.
The 72" side discharge RFM disperses clippings about the same as my zero turn 72" side discharge. I can't tell any difference in cut quality between the 2.
Don't do striping, so I don't know about any differences there.
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
2006 Mack CT713 Granite T/A Galbreath Roll-Off Truck (A55788)
2006 Mack CT713...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A55851)
2016 Toro...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
Indian Head Statue (A53316)
Indian Head Statue...
