Anyone ever change the knives on a Wallenstein chipper?
   / Anyone ever change the knives on a Wallenstein chipper? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Anyone ever change or reverse the knives on a Wallenstein chipper? Was it easy or difficult? I have a BX-60 and would like to reverse the knives.
   / Anyone ever change the knives on a Wallenstein chipper? #2
I need to inspect and maybe flip the knives on my BX-42 soon, but am still running on the original edges after 8-9 years. I have heard it's not very complicated at all. Hopefully none of the bolts are stuck, as that would complicate it.
I think spacing could be an issue, meaning the distance between knife edge and cutting gap..
   / Anyone ever change the knives on a Wallenstein chipper? #4
Not that difficult.
make sure you have proper sized tools
i think they are metric.
small impact might help
   / Anyone ever change the knives on a Wallenstein chipper? #5
I have a Wallensten BX62S. A year or so ago I removed one knife blade. Just to see how it went. It was unbelievably easy. If your blade/anvil clearance is correct - it will be that same way when you rotate the knives or simply reinstall the blades without rotating.
Get them sharpened - you should check the knife/anvil clearances. The anvil may need adjustment.
An added note - any time you remove blades - be certain the blade and blade pocket are absolutely clean. No rust, dirt, smut, etc, etc. This will ensure a correct alignment.
   / Anyone ever change the knives on a Wallenstein chipper? #6
I used to have a BX62. I rotated and sharpened knifes a couple of times. Removing the knives is pretty simple as oosik said. Don't forget to rotate or sharpen the anvil - you have four edges on that. I used a worn hacksaw blade as a gage to set the knife/anvil clearance. Check anvil clearance on all four knifes as there is most likely some height variation and set the clearance using the tallest knife.
2015 FORD F-250 SUPER DUTY (A58214)
2015 FORD F-250...
2013 CATERPILLAR 336E L (A58216)
2013 CATERPILLAR...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58216)
2012 DIAMOND C...
2007 John Deere 6615 (A57148)
2007 John Deere...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
2016 Ford Expedition SUV (A56859)
2016 Ford...
